AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
ACA and MEP compatibility
2 REPLIES 2
Matasovsky
995 Views, 2 Replies
Asking one of those questions I likely already know the answer to, but wish to confirm before making a fool of myself....
Our office uses Project Navigator.  My assumption is the project can be accessed by both ACA and MEP.
I don't need two separate PNs for 1 software, because I'm using ACA and MEP.
Thank you for the quick reply  😉
2 REPLIES 2
robincapperrcd
in reply to: Matasovsky
"My assumption is the project can be accessed by both ACA and MEP" Yes, we have both apps working happily in a single project. Only downside is the project can only spec one default template so either your Arch or MEP users will have to override the project settings when making views & sheets (unless you have all the display settings etc you need for both apps in one set of templates)
Robin
AEC Collection & BIM 360 | Windows Surface Book & HP Z6 Workstation | Android Mobile
RobiNZ CAD Blog
Matasovsky
in reply to: robincapperrcd
My Project Template is already set up to refer to different templates, so I should already be ok there I'd think.
Thanks.  Again, I figured this was the case given the obvious logic that would have to be followed, but could easily see it being a wrong assumption.
”Boost
