Has anyone experienced this with the new 2013 version? I am trying to override a dimension to provide a +/- at the end of one ACA dimension. I added the override, but it is not showing up - even after a regeneration...
Anyone confirm this on their 2013 version or is it just me...
Dave
Solved by davidtetro. Go to Solution.
How are you applying this override? I was able to go into the properties and override the value along with "+/-" within the measurement itself in ACA2013. Are you using a custom style and would it be possible to see a copy of this DWG with this example for testing and viewing?
It was only apparent on one particular ACA string - it worked fine on the rest. I just deleted that string and recreated it and was able to apply the over-ride. Must of been just a bug with that one string - the problem hasn't shown up on any other strings since...
Chalk it up to a buggy dimension string.
