AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
ACA 2013 - Elevation Bug?
52 REPLIES 52
Message 1 of 53
Hugh_Compton
5521 Views, 52 Replies
I've attached a file with a 2D elevation.  The hidden lines are created as continuous lines.  This always worked fine in previous releases.  Is this a bug or have I done something wrong?
52 REPLIES 52
Message 41 of 53
O.Maille
in reply to: barbara.schurig
Hotfix works for me; win7 64, building and infrastructure design suites
Aside - all the shortened typed commands i use are not working; ro, o, m, pl, di etc....
Message 42 of 53
David_W_Koch
in reply to: O.Maille
Has something happened to your ACAD.pgp file?
Has your AutoCAD search path changed, such that the folder containing the ACAD.pgp file you formerly used is no longer in the search path, or is in the search path, but is now below another folder that has an ACAD.pgp file that does not have the specific shortcuts you formerly used?
Looking at the Hotfix Readme, it would not seem as though applying the Hotfix would mess with your keyboard shortcuts.  Were any other changes made (repair installations, re-installaions, overwriting profiles, etc)?
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Message 43 of 53
bec
Nope... still not working...  Windows Xp 64.
I click on elevation mark.. insert, window floor plan and bam... nothing is hidden...    So we have to use autocad 2011 again??????????
Guys...  Seriously...  Now I cant even go back and finish it in 2011...  Section/Elevations commands wont work cause of newer objects...  what a joke...
Message 44 of 53
barbara.schurig
are all your drawings affected?
If yes, could you please upload a small example file including a not correct section?
Did you rename, erase or move the original AecCore.crx file?
Barbara
Barbara Schurig
Support Specialist
Product Support
Autodesk, Inc.
Message 45 of 53
bec
yup...  fixed the file, renamed, rebooted...  here ya go
Message 46 of 53
davidtetro
in reply to: bec
bec - I applied the hot fix and problem went away on my system - all of my elevations display correctly.  I downloaded your drawing and opened it up.  Inserting AEC objects worked (they cut the walls, etc.)  However, I confirmed that you are still having an issue with the elevations - I refreshed, regenerated and even created a new one...
Not sure what the problem is.  Maybe a corrupt drawing.
I copied and pasted all the geometry into a new drawing and ran the elevation - it worked.  You may want to just copy and paste into a new drawing after applying the hotfix and see if it works...may be connected to the actual elevation tool...
Not too sure if this helps you, but worth a try as it worked on my system - Win 7 64-bit.
-Dave
Message 47 of 53
barbara.schurig
in reply to: bec
Hi bec,
Thank you for the file. It seems that your section stile 96 is causing the issue. Here it's marked to keep the hidden lines, if this option is disabled the section looks fine.
I created a small video for zou, it can be watched in your web browser:
change section setting
Please find also attached your file including the changes.
Barbara
Barbara Schurig
Support Specialist
Product Support
Autodesk, Inc.
Message 48 of 53
Art4009
has there been a hotfix for the AEC walls not displaying correctly, in the case where you start with an older version drawing and save it as a 2013 ACA version? I do not need to save a 2013 ACA file down to a lower version, I am happy to use the new 2013 ACA, the problem I have is that the walls dissapear (or leave a single line display) without any warning while I'm working in 2013 ACA........  Any fix to this yet?
Message 49 of 53
barbara.schurig
in reply to: Art4009
I never faced an issue like this. Maybe these walls contail additional information by an application and are not displayed, if pure AutoCAD Architecture is in use.
As this thread is about elevation, I would say this is off topic and I would ask you to create a new post for your question. It would be great, if you could add an example drawing, so we can see how the drawing will show up on our systems. Maybe there are proxies inside.
Barbara
Barbara Schurig
Support Specialist
Product Support
Autodesk, Inc.
Message 50 of 53
MichaelBussiere2
For all posters with this issue, please verify everyone is on the latest build as well.  We recently released update 1 for the ACA0213 software that includes a number of fixes (found in the readme, TOPICS:AEC dimensions, drawing management, grips, layer key, open, sections, schedules, walls, windows crashes, tool palettes <not listed but from testing fixed a number of issues on the ACA/MEP side>, and many more)
ACA2013 Update 1: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20556359&linkID=9240658
Michael Bussiere II
Support Specialist
Product Support
Autodesk, Inc.
Message 51 of 53
thanks, Mike!
Mike Shick
www.medesigns.us
Message 52 of 53
You're welcome and I hope this helps.
Michael Bussiere II
Support Specialist
Product Support
Autodesk, Inc.
Message 53 of 53
ggdesigngc
in reply to: Hugh_Compton
Just replaced the AecCore.crx and elevations now appear correct.
all good to go now.
thanks Autodesk.
”Boost
