Fellow users can you assit please.
I have upgraded to ACA 2013 and I have had nothing but problems and I want to know if I am alone on this. I have uploaded AEC Section Display and Tag Scale Hotfix, http://usa.autodesk.com/getdoc/id=DL19732905,
AutoCAD Architecture 2013 Service Pack 1,
http://usa.autodesk.com/getdoc/id=DL20556359,
AutoCAD Architecture 2013 & AutoCAD MEP 2013 Content Browser Migration Hotfix
http://usa.autodesk.com/getdoc/id=DL18997867
ACA2013 was released and I have had it on the desk for some time and finally I got the nerve to load the upgrade. This I did in accordance with the instructions. The upgrade went well.
I have lost layout tabs completely. I would reload another menu and they would return. I was speaking to another person comparing Autocads and his had the layout tabs and mine did not.
Am I having problems or what !!
Chris
That's quite an unusual set of system problems: system and OS details? Previous ACA version (and is it still installed)>
You wander why I am pissed off with Autodesk. It is very hard to be productive with this B*** S****, constant crashes, had one 1/2 hour ago.
System details
System Information report written at: 10/26/12 23:19:24
System Name: CHRIS-PC
[System Summary]
Item Value
OS Name Microsoft Windows 7 Professional
Version 6.1.7601 Service Pack 1 Build 7601
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name CHRIS-PC
System Manufacturer System manufacturer
System Model System Product Name
System Type x64-based PC
Processor Intel(R) Core(TM) i5 CPU 760 @ 2.80GHz, 2801 Mhz, 4 Core(s), 4 Logical Proce
ssor(s)
BIOS Version/Date American Megatrends Inc. 1003, 24/05/2010
SMBIOS Version 2.6
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume1
Locale Australia
Hardware Abstraction Layer Version = "6.1.7601.17514"
User Name Chris-PC\Chris
Time Zone Cen. Australia Daylight Time
Installed Physical Memory (RAM) 16.0 GB
Total Physical Memory 16.0 GB
Available Physical Memory 12.1 GB
Total Virtual Memory 32.0 GB
Available Virtual Memory 28.2 GB
Page File Space 16.0 GB
Page File C:\pagefile.sys
I have all licensed versions of Autocad ACA. I have ACAD V12 on the system but have not used it for some time. Kept it on until ACAv13 was up and running, this way at least I have a running back up if need be?
I have the version of Fusion V13 that came with ACA V13. I use load ACA via electronic version once and never again. When I encounter a bug at least with the disk it is recognised and will fix the problem, cannot do this with electronic version. I upgraded the computer for ACA v12 and on.
Uninstall ACA2013 and Fusion and any other "goodies" you picked to install from the installation disk/file.
Restart your PC.
Use a quality Windows Registry cleaner to make your system healthy again: I like CCLEANER the freeware version.
Purge/empty your Windows Temp folder (if you got CCLEANER, it can do that too).
Turn of Win7's Aero theme: use the Windows Basic theme instead.
Install only ACA2013, you don't need any Fusion or anything else.
Authorize and run ACA2013: you will have exactly what I have on an almost identical Win7 Pro system, and I only crash occasionally (early last week I believe was the last time).
You are having problems!! It does sound like some heavy issues with the install and to me sound like there might be some problem with the machine. Maybe check your memory as some of what you posted sound like stuff being lost in the nether. But I guess you would say you haven't had problems before 13? There are tools to check memory quality.
For me apart from old bugs that haven't been fixed like SkyFix, snapping to aecobjects etc.
When in paperspace and doing a print preview, you must be outside any viewports or you will get a blank. If in a viewport, you may get a preview but scrolling will make it disappear. Doesn't always occur but often for me so not sure under what conditions.
The actual WYSIWYG no longer works in paperspace with certain conditions. Adesk has my file on this and confirmed the problem. No one else has complained of this so it must be my combination of settings. (same on 4 different machines using same settings).
From 12, using fields to show scale of a viewport only worked up to 1:200 and then it had problems.
I think I may have had one of your issues occur "I have changed from the working model tab to layout tab......" once and I note that sometimes selection of a tab is ignored and you have to choose another and then come back.
btw If I read right, to get the tabs to show up (no longer default) there is a small button visible along the bottom right - only visible IF tabs are hidden.
So whilst I think you have specific machine / install problems, I concur that Adesk is not giving due attention to upgrades
Dean
You are telling me to reload remove the software and clean the registry etc. I do not agree with this for when I had V12 up and running I had a couple of minor issues and once these were sorted out I was all good.
Ever since I loaded v13 I have had nothing but problems. I am not convinced that it is my system that is causing the problems. I had the computer looked at by a GEEK and the system was tidied up and all was well and good. I only began to have the problems when I loaded V13. This is how I lost the data from v12 when migrating and the migrate commands corrupted the v12 software to the point where it would not function.
When I first loaded V13 and all these problems began occuring I was told to do what you said, so I uninstalled v13 cleaned the regitry as directed by Autodesk and then reloaded v13 but the problem did not go away, some of then did but not all.
For goodnes sake why release an upgrade and then have to follow through immediately with SP's and Hot Fixes.
Come On AUTODESK
This is total BS. I have been sitting here with this ACAV13 and I create a 3d solid only to have the software tell me that I have not sellected any solids.
What rubbish is this.
I talk direct to your help desk and it gets to hard so you just leave me hanging.
Nice One.
Did you receive all my automative crash logs for the 30/10/12.
There would have been about 6 wihtin a very short time frame.
Trying to do such a simplet task as zooming within a viewport and yet it crashed, or simply changing from layout to model tab and it crashed.
Where is my HOTFIX ?
I don't have Fusion loaded. There seems to be a little history with Fusion causing others to crash constantly, and removing it seems to work for these folks.
I have everything else almost identical to you: match my setup, and if you still crash, your problem may be way beyond anything Autodesk can do for you remotely. if it doesn't, and I suspect it won't, install Fusion and watch to see if it crashes again.
Autodesk Supported Graphics Cards List and drivers may be what you need as well as changing hardware acceleration settings in ACA:
http://www.autodesk.com/autocad-graphicscard
Pendean
If I understand you comments are you suggesting that I uninstall Fushion and most of my problems should disappear. You mention your settings but did not provide them other than the link to the Graphic Card which I have already been through.
I was actually looking into using Fushion but if you think this may be the cause then I will uninstall.
Adesk suggested I start up in Safe Mode so I tried this and the ACA v13 softwar will not boot for it for is cannot find the "Softlock License Manager".
Pendean
It made no difference weather fusion is installed or not. The system crashed regardless simply changing from layout tab to model tab.
You need to start fresh first before giving up.
Autodesk recommended uninstall/reinstall procedures are as follows
Uninstall: http://usa.autodesk.com/getdoc/id=TS45252
Then get a quality Windows Registry Cleaner (I like the freeware CCLEANER) and clean up your system's temp items and clean up the Windows Registry. Run more than once until nothing is found
Turn off ALL running background applications. ALL of them, no exception. Reinstall ACA.
Ensure the user installing/uninstalling and using the product have enough rights to do so (install and reinstall as local administrator):
Unable to run AutoCAD® as a restricted user http://usa.autodesk.com/getdoc/id=TS1055299
Leave all background running apps closed. Turn off Win7's Aero theme, and change hardware acceleration in ACA if needed. Find and install a tested video card driver from Autodesk if needed.
The last time I did a registry clean or similar to what is being reccommended I had serious problems to the form where I had to reload the entire system due to it not working correctly thereafter.
The last indicident was when I tried to run ACA in diagnostic mode as recommended by Autodesk !
It killed the machine to the point where I could not operate until I had to pay someone to come and fix the problem.
Very reluctant to do so due to past incidents.
I find Autodesk to be one minded they only consider its CAD software with no regards for what else is on the computer. After all its not there down time or costs.
Surely I am not the only one experiencing these problems from what I have read. Why don't they just get off their arses and fix the problems.
Don;t mean to be crude but I am sick of this. Especially when people like this don't give a ****.
I was dealing with Autodesk in the US directly via email and it even got to hard for him so he pissed off and left me standing on my own.
Without the sytem working I don't get paid.
