I'm currently going over the Metric tutorial for ACA 2009. At some point, I'm instructed to right-click the tool palette title bar to select the "project-specific" palette (which should be located among the Design, Visalization, etc palettes). Well, this palette is not there.
I´ve checked the project properties and verified that Project Tool Palette Group is set to Shared workspace catalog. The paths are correct (I'm using Windows 7 x64), etc. When I open antoher tutorial project (Steel Framed Residence_m) the project tool palette is there, but when I create any new project or use the one in the tut, this group/palette is not created.
What am I doing wrong? The profile used to create the project is the default:
C:\ProgramData\Autodesk\ACD-A 2009\enu\Template\Template Project (Metric)\Template Project (Metric).apj
Thanks.
OK, so, after reading more, I found out that the Project Tool Palette Group is actually created, but no palette is created inside it and therefore it is not display in the availabe groups list, but if you go to Customize Palettes, the group is there with no palettes; so, the new questions is: How do I tell ACA 2009 to create a default palette (an empty one) inside the Project Tool Palette Group with the same name as the project itself (to be consistent with the tutorial) ??
I'm thinking there must be a variable to be set or a registry entry messed up.
Anyone?
