AutoCAD Architecture General
Member
howardm
Message 1 of 5 (100 Views)
3D Viewing
100 Views, 4 Replies
06-29-2012 08:40 AM
I recently lost the ability to view a building I was drawing when selecting the 3D cubes. The only thing that shows on the screen after selection is the revised WSC (X, Y & Z) coordinate lines and two dots. Multiple zooms on dots achieves nothing. I can select the "top" cube and return to my plan view with no problem. A couple days prior all 3D modes, shading, etc. worked fine. Configuration problem?
Distinguished Contributor jcp
jcp
Message 2 of 5 (96 Views)
Re: 3D Viewing
06-29-2012 09:24 AM in reply to: howardm
Does the problem only exist when using the view cube or does it happen with all 3d navication methods, orbit, preset view, steering wheel...?
Member
howardm
Message 3 of 5 (95 Views)
Re: 3D Viewing
06-29-2012 09:49 AM in reply to: jcp
All I have tried to use. I tried going into the VIEW drop-downs and got the same results...no 3D viewing. All other commands work fine. Just went from able to see & rotate my views to nothing. Howard J. Moore Tri-Ply Construction LLC Ph.: 509-453-6581 Fax: 509-453-0014 Cell Ph.: 509-728-1398 E-Mail: howardm@triply.com
*Expert Elite*
David_W._Koch
Message 4 of 5 (76 Views)
Re: 3D Viewing
06-30-2012 03:35 PM in reply to: howardm
Are you using an out-of-the-box Display Configuraton, or a custom one?
David Koch
Member
howardm
Message 5 of 5 (75 Views)
Re: 3D Viewing
06-30-2012 03:49 PM in reply to: David_W._Koch
Out of the box
You are not logged in.
Announcements
Need installation help?
Ask the Community
