AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
3D Viewing
4 REPLIES 4
howardm
249 Views, 4 Replies
3D Viewing
I recently lost the ability to view a building I was drawing when selecting the 3D cubes. The only thing that shows on the screen after selection is the revised WSC (X, Y & Z) coordinate lines and two dots. Multiple zooms on dots achieves nothing. I can select the "top" cube and return to my plan view with no problem. A couple days prior all 3D modes, shading, etc. worked fine. Configuration problem?
4 REPLIES 4
jcp
in reply to: howardm
Does the problem only exist when using the view cube or does it happen with all 3d navication methods, orbit, preset view, steering wheel...?
howardm
in reply to: jcp
All I have tried to use. I tried going into the VIEW drop-downs and got the same results...no 3D viewing. All other commands work fine. Just went from able to see & rotate my views to nothing. Howard J. Moore Tri-Ply Construction LLC Ph.: 509-453-6581 Fax: 509-453-0014 Cell Ph.: 509-728-1398 E-Mail: howardm@triply.com
David_W_Koch
Are you using an out-of-the-box Display Configuraton, or a custom one?
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
howardm
in reply to: David_W_Koch
Out of the box
”Boost
