In generating 2D elevations from ADT objects I noticed the muntins didn't match. Anyone have an idea why this might be occuring? I'm sure it's jsut a setting somewhere I've missed. See attached image for example.
Running AutoCAD Architecture 2012.
Solved by MarySeufert. Go to Solution.
Check the window style properties. Make sure the muntins block for each display representation matches one another. ~ Mary
Thanks! That was easy to fix. But, it just seems illogical. When I see muntins_block it makes me think it's a block that follows the window style to any display representation.
Ohh well, thanks again! Kudos 🙂
In the muntins tab there is a check box titled "Automatically Apply to Other Display Representations and Object Overrides". If that's checked then any changes you make to the muntin block will be applied to any other display reps that already have overrides and will keep them in sync.
John
