AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
3 second delay with each dimension placed or altered
4 REPLIES 4
rusharchitect2000
510 Views, 4 Replies
I have a brand new cpu running windows 7- 64 bit, nvidia geoforce 260 card (just updated) and brand new architecture 2011 software.  Every time i place a dimension, move or modify one, it has a three second delay.  Everything else works relatively well, only minor delays here and there which i assume are normal.
Any ideas on how to fix this?  Thank you!
4 REPLIES 4
Do you have the properties palette open?  If so try collapsing the "Lines and arrows" section.
John W. Mumaw
Timber Frame Designer
Lost Bent Woodworking & Design
You are a genius.  Thank you!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I'm glad it worked, but the credit isn't mine.  I myself found it in this discussion group a few months back.
John
John W. Mumaw
Nonetheless, THANK YOU!!!!!!  it almost drove me insane
”Boost
