I would like to add a 2D orthographic view of my model to my drawing. I would like to do this in a manner similar to creating elevations and sections. Is this done with 'Cameras'? I work solely in Model space.
Keene
how do you 'add' it if you only work on model space? Is that a direction from above? If it's your decision alone, learning paper space gives you enormous power and makes this request easy. If not then I know of no solution apart from ......
Try the CREATEHLR command. If you want to get really snazzy you could then run the NAPKIN command on the resulting block.
