I figured out how to create a 2d multiview block. E.g. create plan view, front view and side view with a consistent insertion point and aligned with the proper UCS.
What I can't figure out is how to make the front and side views appear when generating interior elevations or building sections. (Autocad Architecture 2011)
First, you need to have the graphics for the front, left, right and back views "standing up" in the proper 3D orientation. Then you need to define the block with the UCS set to World. If, for example, you are changing to a Front View and the UCS is being changed to allow you to draw in that plane, reset the UCS to World before you make the block.
A more long-winded version of the above (includes step-by-step on the process of assigning view blocks, but has pictures showing block orientation, which may help) can be found here:
http://architects-desktop.blogspot.com/2006/10/multi-view-block-creation.html
I had the elevations drawn in the correct plane. Just realized I needed to tinker with the view settings of the respective view blocks within the MVBlock. That leaves me with the front elevation of the MVBlock with the side elevation visible as a horizontal line. Is there a way to avoid this ? I realize I can edit the elevation "edit in place" and remove the line without affecting the side elevation.
Yup....got it now....just needed to tinker a bit with the view settings.
All I'm wondering now is if MVBlocks can be "dynamic" as well.
It seems that using dynamic blocks within MVBlocks "kills" the dynamics.
I guess the nesting of the blocks causes that.
Would be nice to be able to flip or mirror MVBlocks like ACA Door objects
Although including a "Dynamic block" inside a Mvblock "kills" the dynamics, you can always include a Mvblock inside a "dynamic block" and this works just fine: You can then apply all the "flipping options" and "visibility parameters" the same way you would have done with any other ordinary autocad object. Give it a try.
Regards
aghis
That's a cool suggestion.....why didn't I think of that !! I'll give that a try.
