AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
2014 hangs on draw and modify commands
7 REPLIES 7
Message 1 of 8
604 Views, 7 Replies
the program will hang on draw and modify commands.  I thought it was the MAGNET option for osnap, but that is off.  It happens on almost all draw commands (circle, rectangle, line) and some modify commands (mirror), but not on move or copy.  Anyone else having this issue?
7 REPLIES 7
Message 2 of 8
pendean
This happens in all files? Even if you start a new file?
If you change the Hardware Acceleration Setting in 2014, does the problem go away?
PC and OS specs?
Message 3 of 8
in reply to: pendean
I turned off the Hardware Acceleration and that did not help; made the pointer movement spotty as if the snap mode was on.  It seems that the more entities the drawings has the more the commands hangs.  When starting out a new drawing, there is no issue with drawing a line or rectangle.  However, going into an existing drawing where there are hundreds of entities, the program hangs as if it is searching entities for a point to start.  With MAGNET turned on, it would search for the nearest entitiy, but it shouldn't with it turn off.
I'm using the program on Windows 7 in Parallels Desktop on a Mac OS X (10.7.5) with 16 gb memory.
Message 4 of 8
pendean
2D or 3D file?
How large is the DWG file?
What type of content? Do you use ACA tools and object types?
Our drawings have thousands of objects in them and there is no hanging involved.
Message 5 of 8
both 2d and 3d objects; very large 7mb file.  We use ACA objects.  The 3d objects have their layers turned off.
Message 6 of 8
pendean
Freeze layers instead of off and they don't get audited by AutoCAD commands and functions.
What kind of 3D objects? AutoCAD Solids or multi-face blocks you got from websites like Kohler etc.? 7MB is not huge.
Message 7 of 8
I have found that drawing in the Model Space tab works just fine for all drawings.  The problem comes up with working in  any tab such as WORK-RCP or WORK-FLR.  When working within the viewports the issue of hanging comes about; it has to do with the viewports.  Working in Paper Space on these tabs is just fine...once I switch it to Model Space within the viewports is starts to have issues.
Message 8 of 8
pendean
OK, more good information.
Are you using VPMAX or literally just double-clicking inside a viewport after locking it, zooming in and limiting yourself to that portion of the model?
”Boost
