AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
2013adt saved down to 2007adt.....walls etc won't show up in 2010
2 REPLIES 2
rhots
327 Views, 2 Replies
As above We have 2007, 2010, and 2013arch . Why when saved to an older version of the same software (not plain Jane acad) do the aec objects not show up. I have to export to acad, dump the now bound xrefs, reattach xref's.
This will happen every time?!?!?
Am I missing something? I have proxygraphics set to 1 and proxyshow set to 2.
Please tell me there is a fix for this.
Rick
2 REPLIES 2
pendean
in reply to: rhots
You cannot knock AEC content down a version, it is by design: sorry. There is no fix or workaround unless you want to destroy/explode that all to AutoCAD object types.
You all need to be on the same version of ARCH to work on the same projects: start deviding your teams into 2007, 2010 and 2013 groups/projects. You eventually all need to be on the same exact versions to contiue flawless sharing of files.
rhots
in reply to: pendean
that's what I was afraid of, Thanks Dean
”Boost
