• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Architecture Customer Gallery
    Distinguished Contributor
    Re: Chocolate shop shopfront
    08-07-2008 04:15 PM in reply to: Dermot
    I have added a bit of glitz & glamour. My lecturer said that the signage made the shop look "cheap" so hence the glamour
    It was easier to add these two with photoshop than to change the signage, at least it takes ones attention from the signage.
    Cheers Dermot
    Please use plain text.
    *nathan
    08-07-2008 07:17 PM in reply to: Dermot
    oh that made me laugh!!
    Does spice know that he's out with Elle?
    Nice going Dermot
    David shadow is rather interesting? Getting a bit ahead of himself.
    Ceiling looks great. How did you do that?
    BTW when reducing the size, 1024 wide is prob max width you need to post.
    Maybe if you give the signage a more depth colour rather than just flat?
    How about neon? mmm
    wrote in message news:6001527@discussion.autodesk.com...
    Cheers Dermot
    08-07-2008 07:33 PM in reply to: Dermot
    Nathan
    David & Elles shadows are created in Photoshop so they do not relate to 3d images or should I say the 3d image that they have been pasted onto. but having said that it is not a 3d image that they were pasted onto! So I do not know how to make that work with photshop. One can rotate the shadow 360 deg around the pasted image, but if I put it on his right it does not look good & if I put it on his left he is shading Elle.
    Ceiling is just ACA's standard ceiling material, but I probably have got the material setting fairly right, along with the lighting settings. I have got lights shining up from the floor to light the scene up a bit. The image is saved at that size so I just used it to attach to the post.
    The sign is 100mm deep in the model but the lighting and the setting for the material are making a bit of difference to how it looks. Here is the settings for the render.
    Did the ACA blog crash with your machine?
    Do you want the file for this choc shop?
    Cheers Dermot
    *Wanderer
    08-08-2008 06:07 AM in reply to: Dermot
    dood... that dood is carrying a purse.
    It's a neat design, and the signage does look a little better... the
    only sort of rough-looking element in there now, imho is the potted
    plant in the corner. The pot looks a little jagged?
    > Cheers Dermot
    *Nathan
    08-08-2008 08:49 AM in reply to: Dermot
    No the blog has just been updated.
    I don't have a desktop but everything works.
    I just cntrl-alt-del and use file open to open my shortcut folder and I'm
    away.
    I think I need to run recovery which I hopefully will over the weekend.
    Hey I don't think that door will open! It's about to hit the wall :-)
    wrote in message news:6001601@discussion.autodesk.com...
    Nathan
    post.
    Cheers Derm
    ot
    08-11-2008 12:08 AM in reply to: Dermot
    Its asort of man bag I think, English soccer stars, what do you expect, at US350m for his 5yr contract he has to do something to be noticed.
    Here are a couple of cabinets for inside.
    Cheers Dermot
    08-11-2008 12:12 AM in reply to: Dermot
    Nathan here is another cabinet with your shelves, they have a clear material. And your cabinet.
    I would like to make the shelves sloping, but I cannot think how to do it.
    Cheers Dermot
    *nathan
    08-11-2008 08:20 PM in reply to: Dermot
    If you apply a profile to your shelving that is sloping, it will slope.
    Exactly the same method as I've used for a gutter.
    If you say have two or 3 shelves that are sloping, you can create one
    profile for all of them in one hit.
    Just use the add ring option and the insertion point needs to coincide with
    the bottom of the componant the sweep in applied to.
    As you can add the sweep to a particular componant, the rest can remain as
    defined in the wall style.
    Which of my cabinets did you use? It would be good to get some 3d to the
    endcap. Takes some doing but you can set side back from top and kick back
    from side edge to give it dept.
    How did you do that signage? Looks great!
    wrote in message news:6003083@discussion.autodesk.com...
    Cheers Dermot
