• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Architecture Customer Gallery
    *Arvin, Scott
    Brain Dump - Property Data Enhancements
    657 Views, 11 Replies
    03-27-2003 06:44 AM
    Attached is a brain dump (doc and pdf formats) with information on property
    data enhancements in ADT 2004. Probably of special interest to most of you
    is the information about creating formula property definitions.
    Enjoy!!
    Scott Arvin
    Please use plain text.
    New Member
    Re: Brain Dump - Property Data Enhancements
    03-23-2004 04:33 AM in reply to: *Arvin, Scott
    Do you still have this file? I tried to download it and it seems to be corrupted.
    Thank you,
    Tony Harwood
    *david haynes - imaginit
    03-23-2004 09:05 AM in reply to: *Arvin, Scott
    Here it is Enjoy _____________________________ David Haynes, AIA IMAGINiT Techologies Seattle, WA "Tony Harwood" wrote in message news:9547174.1080045243995.JavaMail.jive@jiveforum2.autodesk.com... > Do you still have this file? I tried to download it and it seems to be corrupted. > > Thank you, > Tony Harwood
    Valued Contributor
    08-10-2006 04:10 AM in reply to: *Arvin, Scott
    How can I call a vb function from vbscript that is executed/fired inside a property set - property formula defintion to show the delta x and delta y values of a line.
    Paul.
    *Nick Haury
    08-10-2006 08:42 AM in reply to: *Arvin, Scott
    1st thing to do is get in the correct NG
    Distinguished Contributor
    08-10-2006 09:01 AM in reply to: *Arvin, Scott
    Where's the rendering? I'm confused...
    08-10-2006 03:03 PM in reply to: *Arvin, Scott
    A bit of history, if you are interested:
    At the time when Scott Arvin originally posted the Brain Dump, attachments were not permitted in all Discussion Groups; he posted the Brain Dump here because this was the one ADT group [or possibly one of two - I can not remember if the Content Discussion Group was active at that time] that permitted attachments.
    David Koch
    Autodesk Discussion Group Facilitator
    Using ADT 2004 at work; access to 2005, 2006 & 2007 at home
    08-10-2006 03:14 PM in reply to: *Arvin, Scott
    As a followup question to an old thread [over three years ago] that was posted in this group due to the attachment limitations of that time, you may find that you get a better response by posting future customization-related questions to new threads in the Autodesk Architectural Desktop Customization Discussion Group:
    Web browser: http://discussion.autodesk.com/forum.jspa?forumID=54
    Newsreader: news://discussion.autodesk.com/autodesk.aec.arch-desktop.customization
    So far as I know, you can not call an external VB function from within a Formula Property. There also appears to be an issue with using VBScript within a Formula Property to retrieve usable point values. See
    http://discussion.autodesk.com/thread.jspa?threadID=482490
    for more specifics on the problem I had had, and note the lack of response.
    See also
    http://discussion.autodesk.com/thread.jspa?threadID=483853
    http://discussion.autodesk.com/thread.jspa?threadID=455589
    David Koch
    Valued Contributor
    08-11-2006 03:39 AM in reply to: *Arvin, Scott
    Having read all the topics and links it appears that no one has found a way to do it yet!
    Is that right?
    08-11-2006 09:48 AM in reply to: *Arvin, Scott
    I have never gotten it to work. If others have, they are not sharing their secrets.
    David Koch
