• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Architecture Content
    Active Contributor
    nstalker
    idrop not working
    345 Views, 3 Replies
    06-12-2012 06:49 AM
    I am dragging and dropping content from the "design tool catalog - imperial" into ACAD Architecture 2013 and nothing is happening.  I don't even get an error message or any indication that a command was processed in the command line history, even when I expand the history with F2.
    Please use plain text.
    Valued Mentor
    leothebuilder
    Re: idrop not working
    07-17-2012 06:58 AM in reply to: nstalker
    When you say "dragging and dropping" are you dragging tool palette tools into your drawing area?
    You need to drag tool palette tools onto your tool palette, then use the tool from the palette.
    Active Contributor
    nstalker
    07-17-2012 07:00 AM in reply to: leothebuilder
    thanks!  Seems like I used to be able to drag and drop into the drawing in 2012 though.  I have been copy and pasting into the tool pallete in the meantime.
    07-18-2012 02:29 PM in reply to: nstalker
    You should be able to i-Drop a tool directly into the Workspace and have it work.  I am vaguely recalling that there was an issue with this in the past, but cannot remember if it was with ACA 2012.  Do you have all of the service packs and hotfixes installed?
    David Koch
