• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Architecture Content
    Active Contributor
    Re: Area Tag to Polyline Help
    08-22-2009 11:22 AM in reply to: objectfield
    Hi David
    this is really great and something I've been looking for for a while. Just wondering if this is still the right way to go about tagging a series of plines with room name number and area for eventual extraction into a table. I am using acad 2009.
    also, though I've only just dug into it, I am unsure at one point do you connect the pline to the block for the area calculation?
    many thanks
    Please use plain text.
    08-22-2009 02:32 PM in reply to: objectfield
    The example posted here is based on using Architectural Desktop (since the 2008 release, renamed AutoCAD Architecture), which is a vertical extension of AutoCAD. If you are using vanilla AutoCAD, and not AutoCAD Architecture, then the example here will not be of use to you.
    If you are using AutoCAD Architecture 2009, then you should be able to open the sample file posted above and see how things work. You would need to make a Schedule Table Style to display the Property Data in "table" format; you would not be using an AutoCAD Table.
    David Koch
    Active Contributor
    03-09-2010 10:30 AM in reply to: objectfield
    I use a field code to attach a polyline to th room tag. One right clicks and pick object under Field names and then one picks the polyline under the new window of object. This will tag the room tag to the polyline and if one changes the size of the polyline then you just update the field in order to get the new size. Hope this helps.
    04-02-2010 02:50 PM in reply to: objectfield
    I have been bashing my head off and on over the last year or two trying to figure out how to do this in AutoCAD. Not Revit, ADT, or anything else but just good old AutoCAD.
    The 'Field' command is a good start but the challenge I have is that there are about 200 rooms and in several files that I need to assign the room tag to. I essentially want to do what David has done in his example drawing but I'm not using ADT and I need to add a couple more tags of information. Is there a way to insert an attribute block and then associate it to a polyline? I already have the polylines all drawn I just now need to associate the tag information and area to them.
    I also want to extract the data to an Excel file for further financial work. In turn I will be modifying the rooms and will need to export them again later to show a comparison of before and after. It would wonderful to link the Excel file to the drawing so as rooms are added, modified, or deleted in either file they will be updated in the other. I realize that I probably wouldn't be able to physically 'delete' a room in Excel and if it delete in the CAD file but I'm thinking more about having the information connected.
    Anyone know how to achieve this or tell what book I can buy that will explain it?
    M Shaw
    Active Contributor
    04-05-2010 10:55 AM in reply to: objectfield
    I just got some email tips that may be helpful to you. Email me at bgempp@umassd.edu and I will gladly forward the email to you.
    Regards
    04-19-2010 10:22 AM in reply to: objectfield
    bgempp, sent you an email with email address. Not sure if you got. Interested in whatever insight or tips you have.
    Active Member
    12-23-2011 02:23 AM in reply to: mbshaw77
    I have downloaded this routine and got it working. so far so good.
    But now I want to extract the data with dataextraction to an excel sheet and there I'm stuck.
    I see the different attributes but not the data inside the attributes,
    Can anybody help me on a how to...
    thanks in advance..
    12-23-2011 06:57 AM in reply to: RKoopman
    If you are using AutoCAD Architecture (and not just plain AutoCAD), and are using Multi-View Block Schedule Tags to display the information, you will not be able to use vanilla AutoCAD attribute data extraction techniques (as far as I know, anyway).
    What you can do is set up a Schedule Table Style that applies to polylines, include a column for each property you want to export, place an instance of the Schedule Table in your drawing and select all of the polylines you want included in the selection set of the Schedule Table.  Select the Schedule Table and, on the Schedule Table contextual ribbon tab, on the Modify panel, choose the Export tool.  -OR-  Select the Schedule Table, right click, and choose Export from the contextual menu.  Set the Save As Type and set a File Name (and location)  in the Export Schedule Table dialog, and click OK.
    If you have any problems following the brief outline above, post back, and indicate what version of AutoCAD Architecture (or Architectural Desktop) you are using.
    David Koch
    Active Member
    12-23-2011 07:04 AM in reply to: oompa_l
    Thanks for the quick response.
    We are using ACA 2012
    I will try your solution, but for now, just found another way to export the data..
    >Export > Property data.
    ...works for us.
    Happy Holidays
    Ruud
