AutoCAD 2013/2014 DWG Format
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
trim
- Highlight
- Email to a Friend
- Report Inappropriate Content
Hi
I posted a file drawing of a basic symbol.....how do i trim the circle segment between the 2 red lines?
I have drawn this symbol in space....should i be anchoring it to the 0,0 co-ordinates?
Thank you for any help
Re: trim
- Highlight
- Email to a Friend
if edges don't cross or at least touch the object to trim ... they can't be used for trimming.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
Re: trim
- Highlight
- Email to a Friend
Thanks Alfred
Re: trim
- Highlight
- Email to a Friend
I redone the sketch .. what tool is ideal for getting lines to touch circles...i keep getting either small gaps or small overhangs of lines when using circles...
I not now getting the Trim to work because of small Gap...so the lines just need to touch the circle for the Trim to work
Sam
Re: trim
- Highlight
- Email to a Friend
in case of overlap use _TRIM (and the circle is the cutting edge)
in case of short distance to circle use _EXTEND then
HTH, - alfred -
Alfred NESWADBA
Re: trim
- Highlight
- Email to a Friend
You should never have gaps - draw to intersection and/or use geometric constraints.
Are you sure you have gaps? Viewres 2000 or higher and REgen.
Are you in the BLock Editor when trying edit (a trim would count as an edit) your block?
Re: trim
- Highlight
- Email to a Friend
The question of what context you are doing the trimming matters. You can't trim a block except during a refedit session or bedit session.
In bedit there is no problem trimming, but there have been constraints applied to the object and so the trimming operation will likely disrupt those constraints.
