• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Member
    "Qleader" Setting Question
    267 Views, 4 Replies
    05-02-2012 11:36 AM
    When i type "qleader" and go to settings and then check the "Always left justify" option under MText Options it will not save.  I go open up another drawing and have to do this again.  Is there anyway for it to keep the setting?  Thanks in advance for your help.
    Please use plain text.
    *Expert Elite*
    pendean
    Re: "Qleader" Setting Question
    05-02-2012 07:37 PM in reply to: crabbygraphs
    it is a per-file setting, not a global setting.
    Dean Saadallah LT BLOG | RSS Feed | LT Tips | PINS
    *Expert Elite*
    05-03-2012 12:49 AM in reply to: crabbygraphs
    If you want that option set in every drawing you open,  you can add a snippet of code to your ACAD2013DOC.LSP file.
    See this article for the code that allows you to set your Qleader defaults:
    http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/QLeader-attachment/td-p/1445617
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    New Member
    MatthewMilner2247
    07-24-2012 05:52 AM in reply to: tcorey
    So are you going to fix this in a patch, or am I going to have to learn code?
    Valued Mentor
    TrevN
    07-24-2012 08:21 AM in reply to: MatthewMilner2247
    Or use Multi Leader?
