AutoCAD 2013/2014 DWG Format
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
model documentat ion problem with ghost objects
- Highlight
- Email to a Friend
My group and I are getting an infrequent but annoying problem with Model Documentation (MD) generated views in paperspace layout tabs. We all on autocad 2013, with sp1.1 installed on x64 machines.
We are seeing objects/ blocks showing in the MD views (viewbase created) in the layout that are no longer in model space. One common factor in this is that these objects seem to always be externally referenced (xref) files that have been either unloaded or completely detached (both cases purges preformed afterwards to wipe any remaining blocks made no difference). In this latest case the ghost objects show up twice (we needed 2 of the same xref) at what appears to be the correct old coordinates.
We have no work around for this and when this occurs we either have to revert to an older version from vault or create a new dwg, port all information over and recreate all views. The interesting thing about this problem is that if we revert to an older version from vault, the ghosts do not reappear/ reoccur at the same commands they appeared at previously.
Re: model documentat ion problem with ghost objects
- Highlight
- Email to a Friend
Additionally, I want to add that any other views created on any layout tab would now show the ghost objects eventhough they are not present in the model after they appear the first time.
- Highlight
- Email to a Friend
Would it be possible for you to provide both your workflow and a sample file where you are experiencing this issue?
Steve Bessette
Support Specialist
Product Support
Autodesk, Inc.
