• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    nuwul
    how to scale the layout view but remain the viewport view?
    2025 Views, 8 Replies
    05-16-2012 10:12 PM
    i have a template, created a viewport and fit the model view in the layout space. However, when i scale the template... the viewport model doesn't follows the layout scale. Is there any ways to fit it so that when i scale the template i don't have to set the view again
    Please use plain text.
    *Expert Elite*
    Re: how to scale the layout view but remain the viewport view?
    05-17-2012 04:01 AM in reply to: nuwul
    A template is a file, that can't be scaled.
    If you think about scaling the layout then you have to define a pagesize half or double (or whatever resized compared) to your existing setting. Then go into the layout and scale the viewport, your titleblock, and all geometry on paperspace.
    Another option may be to just set a scale-factor in the page-settings-dialog. That does scale the plot-output, but some scale- settings within this layout are then inconsistent. So be careful about every anno-scaling or scale-depending options, e.g. if you have a titleblock with 1:1 as scale-definition this is wrong then.
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    hardin
    05-17-2012 08:13 AM in reply to: nuwul
    I'm not following...
    Are you actually scaling the border and viewport in paperspace?
    Learn, Practice, Get Better
    http://autocad-lkh.blogspot.com
    *Expert Elite*
    05-17-2012 09:59 AM in reply to: hardin
    That was me, who was not following ("scaling template") :smileywink:
    If I reduce the layout then yes, I would also have to scale all paper-space elements. That includes all viewports and title-block and border and legend and ... whatever is placed there.
    - alfred -
    Alfred NESWADBA
    hardin
    05-17-2012 03:13 PM in reply to: alfred.neswadba
    Are you changing border sizes from ANSI D to an 11x17 or something?
    If so, the viewport won't scale it's scale (so to speak). You'll have to scale the paperspace objects, then reset the scale in the viewport appropriately.
    I hope you're not scaling your border and viewport so you can plot at 1/4" = 1'=0" instead of 3/16" = 1'-0" or something like that.
    Are you just changing the size of the border because you need to print a different paper size?
    If you supply the reason why you want to scale the viewpor, we might be able to work something out or suggest a work around for you.
    We use ANSI D (34x22) borders and print at 1:2 for 11x17 prints or plot at 1:1 for full size ANSI D prints.
    *Expert Elite*
    05-17-2012 09:50 PM in reply to: hardin
    >> Are you changing [...}
    No, I'm not changing anything, the OP wants something like that, but he was not back yet to describe whatfor he needs that.
    I did nothing else but show 2 ways to come to the result as I understood his question.
    - alfred -
    Alfred NESWADBA
    hardin
    05-18-2012 07:09 AM in reply to: alfred.neswadba
    Sorry Alfred, I did mean that as a reply to the OP...
    New Member
    02-08-2013 07:17 AM in reply to: hardin
    I have a question for you.
    I have a drawing drawing 1:1 in the model space and would like to print it to a 1:100 scale using layout.
    The question I have is how do I get the correct scale using the layout feature in AutoCad?
    I tried using the vp scale on the bottom right of the screen but there are different 1:100 choices each producing varying scales. Please he
    02-08-2013 02:08 PM in reply to: Jlosier
    What are your units set to in the dwg? When you say there are multiple 1:100 scales, do they all show exactly the same?
