• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2013/2014 DWG Format
    Valued Contributor
    dwg to dgn
    185 Views, 2 Replies
    11-13-2012 08:58 AM
    Using 2013, I have a drawing created in that other software ( Microstation). I opened it in autocad, and did some work to it. Now when I send it back, they can't open it any suggestions?
    Please use plain text.
    Active Member
    Re: dwg to dgn
    11-13-2012 10:55 AM in reply to: blowout
    blowout, they are probably not using the most current version of MicroStation.  Only MicroStation V8i (SELECTseries 3) Update 1 v08.11.09.357 will open the 2013 DWG file format.
    HTH,
    Bob Mecham
    Training | Consulting | Programming
    www.EnvisionCAD.com
    Facebook: http://www.facebook.com/EnvisionCAD
    Twitter: http://twitter.com/envisioncad
    Youtube: http://www.youtube.com/user/envisioncad
    Valued Contributor
    Re: dwg to dgn
    11-13-2012 11:28 AM in reply to: mechamb
    Thanks, Bob Mecham. They are using V8i Select. I found out byexperiment that when i use 3d seed file as i click thru the process, it works. But even though the files are 2D, the 2d seed file setup does not work. Does that make sense?
