• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    New Member
    develop profile /section
    82 Views, 4 Replies
    02-06-2013 02:54 AM
    I am having topograghical map of area with elevation. how  section/profile along a line which cuts multiple contour can be generated.
    Please use plain text.
    *Expert Elite*
    Patchy
    Re: develop profile /section
    02-06-2013 05:12 AM in reply to: shankarnhpc
    You need C3D for this job.
    Valued Contributor
    02-06-2013 06:28 AM in reply to: shankarnhpc
    If you rotate the UCS so as you are looking at the side elevation you can 'DVIEW', 'CLIP', 'FRONT' and drag the slider to get the right section. Then exit and do a 'FLATSHOT' of the view. That will make a passable section that you can revise if needed.
    Valued Mentor
    TerryDotson
    02-06-2013 08:23 AM in reply to: shankarnhpc
    If you were to consider third party add-ons, the low cost MapWorks Sections module will let you quickly create profiles and sections directly from your AutoCAD geometry.
    Valued Mentor
    TrevN
    02-06-2013 08:54 AM in reply to: TerryDotson
    Or draw it the old fashioned way! :smileyvery-happy:
