• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Accepted Solution
    changing block units
    172 Views, 2 Replies
    12-03-2012 06:38 PM
    i looked for this problem but it seems impossible, i have a dynamic block and it unit is unitless . i want to change it to mm .
    if i use the command " bmake " the dynamic block will be lost because autocad will redefined the block and it can not redefined dynamic block.
    also its a complicated block i can not make it again .
    Please use plain text.
    *Expert Elite*
    Re: changing block units
    12-03-2012 08:37 PM in reply to: mr-_-small
    With _BMAKE you create a new block-definition. But as I understand your situation you already have a definition and you want to edit/modify that. In that case you should use _BEDIT (>>>details<<<) to get into the blockeditor, there you can set the block-units within the property-window (<CTRL> <1>).
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    12-04-2012 04:34 AM in reply to: mr-_-small
    yaaaa you are the man .... thank you alot .:smileyvery-happy:
    that exactly what i want .. you are awesome.
    i search for this in this fourm but no such an answer like this ...  glad you here...
