• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    can't delete holes in surfaces....
    281 Views, 8 Replies
    04-16-2012 11:41 AM
    Hi, I have attached a file that has a surface, with holes in it.  I need to heal the surface, or remove the holes.
    In old mechanical desktop, when you untrimed the surface, the holes would go away. Now untriming does not eliminate the holes and extending the surface inward does not work either.
    Am I missing something?  This seems like it would be a common task to need to be able to do with surfaces.
    Thanks!
    Please use plain text.
    Re: can't delete holes in surfaces....
    04-18-2012 07:01 AM in reply to: hypersonic
    In old mechanical desktop.....
    Hasn't been sold as a product by Autodesk since Feb 2002.
    Most users doing this type of work have updated to Autodesk Inventor.
    Inventor indicates quality problem with your surface.
    I was able to get Inventor to Refit the surface to pass quality check.
    04-18-2012 07:07 AM in reply to: hypersonic
    Using a modern program like Autodesk Inventor it is trivially easy to untrim the surface.
    In this case I elected to remove the wires (boundaries of the holes), but they could be kept if needed for reference.
    Active Contributor
    04-18-2012 10:50 AM in reply to: hypersonic
    Done with Acad 2013.
    Thanks Autodesk for AutoCAD's evolution.
    04-18-2012 12:00 PM in reply to: PaulCloutier
    Doesn't look like the same surface to me?
    04-19-2012 07:11 AM in reply to: JDMather
    Would Fusion do the same stuff?
    04-19-2012 07:16 AM in reply to: PaulCloutier
    Paul, what commands did you use to do this in AC2013?
    Thanks!
    Active Contributor
    04-19-2012 10:20 AM in reply to: hypersonic
    Xedges
    or
    Solidedit -> Edge -> Copy
    Edges are turned to splines or arcs
    For arcs then -> Pedit -> Spline
    Use Join to join Splines (use the grips and Osnap END if the dont join)
    Must have 4 Splines to use Surfnetwork (two sides and both ends)
    You can modify the new surface U and V isolines in the properties
    This is my way...maybe a better one ?
    04-19-2012 11:20 AM in reply to: PaulCloutier
    Yes, but then I think you might loose the surface shape that it had originally, I think that is what JD might be trying to point out.....
