• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Windows 8, AutoCAD, Revit
    741 Views, 5 Replies
    02-05-2013 01:52 PM
    Just wondering if anyone has any new suggestions about installing and using AutoCAD (and Revit) in Windows 8? I'm aware that Autodesk does not currently list Windows 8 as a supported platform. However Autodesk has started to provide support for some of it's products on Windows 8, just not AutoCAD yet.
    Please use plain text.
    *Expert Elite*
    Re: Windows 8, AutoCAD, Revit
    02-05-2013 02:53 PM in reply to: kmfinchpdx
    Sorry, but if you need a stable environment for your AutoCAD then the only answer available is not to use Win8 currently.
    What's the need to install Win8 now, I don't see any advantage using Win8 with AutoCAD? Use Win7 and it's working fine.
    Even when Autodesk releases a servicepack to be compatible with Win8 I would not want to be the first one who's trying that (except I have a test system).
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    02-05-2013 03:04 PM in reply to: kmfinchpdx
    As I said in my posting I am aware that AutoCAD is not supported on Windows 8 at this time. :smileysad:
    I purchased a new computer recently because my old one with Windows XP was getting too slow to run AutoCAD and would not run Revit at all. Windows 7 isn't sold anymore with new computers.
    In my posting I asked for suggestions about installing and using AutoCAD & Revit in Windows 8.
    *Expert Elite*
    02-05-2013 03:10 PM in reply to: kmfinchpdx
    But Microsoft has a program for these cases to "downgrade" your Win8 license. And that is what I would do.
    You might search for Win8 in this forum and you'll get a lot of info. I don't think that you will get any more informations in a new thread as it is not stable at the current date. You might have luck to get it installed or not, you might have luck to have it running then or you need double time in your work because of crashes.
    But let's see, maybe anyone here can say "do these xxx steps and you will be stable then" (I doubt).
    - alfred -
    Alfred NESWADBA
    02-05-2013 03:30 PM in reply to: alfred.neswadba
    Thanks for your reply but that wasn't what I was asking for. I have done searches but most are buried deep in the boards where most don't look.
    Downgrading brings a whole host of problems with it. Seems likely that Autodesk will include Windows 8 compatibility with AutoCAD 2014 when it is released later this year. 2013 probably would have been Windows 8 compatible had the release date been a few months earlier instead of October.
    *Expert Elite*
    pendean
    02-06-2013 11:28 AM in reply to: kmfinchpdx
