• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    JamaL9722060
    Why the “dimensions” doesn’t respond as the “annotation scale” changes…
    286 Views, 6 Replies
    10-09-2012 01:45 PM
    I’m wondering why the “dimensions” doesn’t respond as the “annotation scale” changes when the “Automatically add scales to annotative objects when the annotation scale changes” is OFF?
    Thank you
    Best
    Jamal
    Jamal NUMAN, GIS and Civil Engineer, MSc
    e-mail: JamaL9722060@yahoo.com
    P.O.Box: 731, Ramallah, West Bank, Palestine.
    Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
    Windows 7 (Ultimate 64 bits),
    Firefox 20.0,
    Kaspersky 2013.
    Please use plain text.
    pendean
    Re: Why the “dimensions” doesn’t respond as the “annotation scale” changes…
    10-10-2012 05:23 AM in reply to: JamaL9722060
    Are you using an annotative dimstyle?
    Again, posting a DWG instead of a screenshot would answer your questins more quickly.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    *Pro
    10-10-2012 07:01 AM in reply to: pendean
    Dean is right, the dimstyle needs to be set to ANNOTATIVE.
    That's the first thing...
    The second thing is that maybe those dims haven't had any additional Annotative Scales assigned?
    The third, and probably the most dangerous thing, is that I can tell by the screen capture you supplied that the ANNOAUTOSCALE button is turned off.  If it was turn ON, then anytime you change the Annotation Scale factor, EVERY annotaive object will have that scale factor assigned.  Again, this is a "DANGEROUS" setting because you may not want every annotative object to be assigned with every scale factor.
    JamaL9722060
    10-10-2012 01:35 PM in reply to: murray-clack
    Many thanks for the help guys.
    This is exactly what I’m saying: as long as the “ANNOAUTOSCALE” is off then the dimension will never respond regardless the change of the “annotation scale” value!
    Why the “ANNOAUTOSCALE” necessarily to be turned ON to let the dimension respond once “annotation scale” changes?
    The file is attached
    Firefox 20.0,
    Kaspersky 2013.
    pendean
    10-11-2012 05:35 AM in reply to: JamaL9722060
    Are youo asking why does the feature you want need to be turned on? Kind of like wanting orange juice but not using any oranges :smileyhappy:
    *Pro
    10-11-2012 07:34 AM in reply to: pendean
    Dean:  " Kind of like wanting orange juice but not using any oranges"
    You mean like TANG?
    JamaL9722060
    10-12-2012 01:37 PM in reply to: murray-clack
    thanks anyway.
    best
    Jamal
    Firefox 20.0,
    Kaspersky 2013.
