• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Member
    Warning while opening a file
    156 Views, 2 Replies
    12-31-2012 12:50 AM
    While opening the autocad file it is showng some warning & I dont know what is this.
    Let me suggest anyone.
    Reg,
    Sudhi
    Please use plain text.
    *Expert Elite*
    rkmcswain
    Re: Warning while opening a file
    12-31-2012 06:22 AM in reply to: SUDHI.KN
    Are you using AutoCAD or AutoCAD Mechanical?
    Is the drawing from AutoCAD Mechanical?
    Valued Contributor
    12-31-2012 06:31 AM in reply to: SUDHI.KN
    Hello SUDHI.KN
    What you are tryingto open is a file in which "Annotation Scales" are used. Annotation Scale was first introduced by Autodesk in AutoCAD 2008/ AutoCAD LT 2008 products. Learn more on this here:
    http://lynn.blogs.com/lynn_allens_blog/2007/03/more_autocad_20.html
    http://lynn.blogs.com/lynn_allens_blog/2008/11/an-autocad-hip-tip-on-annotation-scaling.html
    http://www.cadalyst.com/cad/autocad/awesome-annotation-scaling-circles-and-lines-autocad-tutorial-61...
    http://heidihewett.blogs.com/my_weblog/2007/05/annotation_scal.html
    I think I have given you enough links. Now copy your file elsewhere and give a new name. Now open the file and go ahead ignoring the message. The file will open alright. Only thing is that you will not be able to edit the mechanical symbols which have been done under annotative scaling. Probably you have to erase it and re do it if you wanted to change it.
    Hope my 2 cents of advise helps. Those links will definitely help you better.
    With best regards
    PRSS
