• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    New Member
    Re: View problem when switching from paper space to model space
    05-03-2012 04:09 PM in reply to: simon.thouin
    I am using Civil3D 2013 and am experiencing the same problem with random drawings. Very annoying bug!!
    Please use plain text.
    Va1
    Active Member
    05-14-2012 05:50 PM in reply to: simon.thouin
    Same problem here I am running Infrastructure. The civil 3d users in the office are having issues as well.
    Member
    danjvaldez
    06-28-2012 09:10 AM in reply to: simon.thouin
    Just wanted to put it out there that I too am having this problem randomly with Civl 3D 2013. Model space plan view automatically sets itself to 44.4 degrees on the XY axis and 0 degrees on the Z when switching from paperspace to model space. Easy thing to fix by setting the plan view to pre-saved UCS but a permanent fix would be nice.
    New Member
    dtrapp
    07-23-2012 12:38 PM in reply to: simon.thouin
    I'm having the same problem here and it is very frustrating.
    Does anyone have an idea when this might be fixed?
    New Member
    09-14-2012 10:06 AM in reply to: simon.thouin
    I am having the exact same isse with a project. The view rotation only happens with some of the drawing files. I have researched this issue and have not found a solution.
    *Expert Elite*
    BrianHailey
    09-14-2012 10:49 AM in reply to: simon.thouin
    I don't know why it's doing it but it has something to do with having UCS not set to world and/or a twist to your view. Do this,
    • Create a new drawing using the default template in C3D.
    • Draw a rectangle.
    • Run the DVIEW command and twist the view (I used 30 degrees).
    • Switch to a layout.
    • Switch back to the Model.
    • You could also rotate the UCS around the Z axis in lieu of the DVIEW command.
    http://screencast.com/t/437t6JYD
    *Expert Elite*
    BrianHailey
    09-14-2012 12:04 PM in reply to: BrianHailey
    Just a follow up (since I can't seem to be able to edit that last post). Those instructions aren't to fix the issue. It just shows what is happening and how to recreate it.
    10-11-2012 12:59 PM in reply to: BrianHailey
    I am using Civil 3D 2013 and am having the same problem consistently. When i switch Layout tabs or open a drawing that has the Model Layout saved in an alternate UCS (any other than WCS) the view then "twists" to a parametric view.
    There have been several suggestions as how to workaround this issue, that's great. I have found if you simply select Undo (Ctrl+Z) immediately following the drawing being opened and "twisting" the view or switching Layout tabs the view will go back to what you're expecting (plan view with your alternate UCS set).
    Just thought I would share.
    New Member
    jking
    10-12-2012 08:13 AM in reply to: luconceicao
    I noticed that this (Autodesk) reply was in May of 2012 and stated that they are aware of this problem.  I am still having this problem and it seems ridiculous that I have to use the command Plan (current) everytime I switch between paperspace and modelspace.  I recently received an update for my AutoCAD 2013 Map3D and I still have this problem.  Is anyone working on this still?  Its very disapointing to have to deal with a problem like this with software of this caliber.
    *Expert Elite*
    rkmcswain
    10-12-2012 09:12 AM in reply to: simon.thouin
    Add me and several C3D 2013 users here to the list of people waiting on this bug fix.
