• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Unhandled Access Violation reading 0xffffffff exception at e14572a7h
    405 Views, 5 Replies
    02-14-2013 12:06 AM
    Hi Everyone,
    We're trying to elete an object with a constrain on it in ourdrawing. Problem is, when we try to either delete the object or remove the constraint on it, our AutoCAD 2013 crashes with the error in the subject. Additional detail is that the file was created in a lower version, I'm hazy on it but I think it was created on AutoCAD 2011.
    Has anyone else encountered this problem? Thanks. :smileyhappy:
    Please use plain text.
    *Expert Elite*
    rkmcswain
    Re: Unhandled Access Violation reading 0xffffffff exception at e14572a7h
    02-14-2013 04:59 AM in reply to: ronane
    Is this a crash you can repeat in any new empty drawing, or does this only happen in a particular drawing?
    02-14-2013 05:18 PM in reply to: rkmcswain
    Hi rkmcswain,
    The error is only for a specific drawing.
    Distinguished Mentor
    braudpat
    02-14-2013 11:36 PM in reply to: ronane
    Hello
    Could you open your DWG in RECOVERY Mode and then Re-Save it ...
    Have you yet the same problem ?
    Bye, Patrice
    02-14-2013 11:53 PM in reply to: braudpat
    Hi Patrice,
    Thanks for the reply. We can't open it in RECOVER, it just crashes. It just says  "problems were were detected. recommend that you save your work and restart program."
    braudpat
    02-15-2013 02:48 AM in reply to: ronane
    Hello
    Aie, Aie, your DWG seems very damaged !
    An other idea : from a blank DWG with correct Units
    Try to insert it at 0,0 - Rotation = 0 - Scale = 1 - In exploded mode
    If OK, please try immediateley an AUDIT
    Good Luck, Bye, Patrice
