• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Distinguished Contributor
    Re: Unable to save change to right click customization
    10-04-2012 05:13 AM in reply to: ddavid
    I just tried turning off the Autocomplete "suggestion list" and that seems to force right click enter to actually enter instead of having to press it twice. Right click on the command line and choose the autocomplete flyout to change.
    Please use plain text.
    10-04-2012 05:15 AM in reply to: OrionHE
    Try turning off the autocomplete suggestions list
    Active Member
    10-04-2012 01:25 PM in reply to: dmmeehan
    Thank you for understanding my problem and resolving it.  I unchecked "Auto-Append" and my flow is back.  Thank you again!
    Member
    04-02-2013 06:40 AM in reply to: OrionHE
    I got to the end of this string and I was disappointed to see no final answer to the question.  So I am posting this answer.  If you turn on "Turn on time-sensitive right-click:", it will lock the Default Mode, Edit Mode and Command Mode to whatever you set it to be, see attached.  To make changes to the settings, uncheck "Turn on time-sensitive right-click:", make necessary changes then re-check "Turn on time-sensitive right-click:".
