• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Member
    Unable to directly copy/paste into Word/Office
    762 Views, 4 Replies
    09-07-2012 09:11 AM
    I recently upgraded from Autocad 2012 Mechanical.  Previously, I was able to simply select objects in AC, ctrl-c them, then paste them into Word.  I am now using 2013 Product Design Suite, with the Vault addin for word.  I am now unable to do this.  What I notice is that when I switch to my Word window and paste, there's some unknown process occurring in Autocad.  Furthermore, what should be an image box with my drawing in Word is a blank box.
    Has anyone else experienced this problem with upgrading to 2013?  I'm hoping there's a solution that's just as easy as it was with 2012.  I do this several dozen times an hour, so it's not very time-efficient to export files to .bmp, .png, etc and then load them into word; I'd like to do this with a simple copy/paste.
    AutoCAD:  2013 Product Design Suite, using 2013 Mechanical.
    Word:  2007, Service Pack 2.
    Please use plain text.
    Member
    Re: Unable to directly copy/paste into Word/Office
    09-07-2012 09:48 AM in reply to: Pochuck
    Some additional information, I've noticed a warning when I do this: "SketchBook Designer data can only be saved in DWG file format and will be omitted from other file types".  I suspect this may be the culprit.
    As far as the extra process in Autocad, it looks like it's actually trying to imbed the file into word, not just the image.  I have to edit the image, which swaps me back to Autocad so I can do a zoom extents, save, THEN it appears in word.  However, not all layers appear even though the layer manager shows them as being plotted.  It also looks like it hates blocks, they're not showing up either.
    This problem has stumped even my reseller.  They've been unable to find a solution so far.
    pendean
    09-10-2012 06:02 AM in reply to: Pochuck
    With no Sketchbook Designer installed here (and plain AutoCAD where you are posting, not MECH), we have no issues doing what you seek. But we also use MSOffice 2010.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Member
    09-10-2012 04:12 PM in reply to: Pochuck
    In that case, is there any way to disable Designer without simply deleting it?  I may need it again in the future, and I have zero luck finding instructions on doing so.
    09-11-2012 05:50 PM in reply to: Pochuck
    Instead of copy paste, does the Windows 7 snip tool help?
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
