• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    New Member
    UCS roated in Block Editor?
    94 Views, 1 Replies
    01-04-2013 06:34 AM
    I am working with 2013 in 2D
    Somehow I switched my UCS without noticing from X,Y,X to Z,Y,X. Though the UCS was changed my layout never switched orientation (flat square remained flat square and did not turn into a line).
    I was alerted to the error when inserting the blocks. Half of the blocks were showing up as thin lines (in the Z plane) and half where showing up in the X plane.
    I was able to correct the UCS by typing UCS, world view, then PLAN, current.
    My question now: How can I fix the blocks that where "created" in the Z plane so that they can be inserted into the X plane without having to 'rotate3d' every time I insert a block??
    Please use plain text.
    Active Member
    Re: UCS rotated in Block Editor?
    01-15-2013 02:39 PM in reply to: Namth
    You might have to edit the block itself and 3drotate just once.
