AutoCAD 2013/2014 DWG Format
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Re: Toolbars keep resetting & draw order doesn't seem to work.
- Highlight
- Email to a Friend
What am I looking for in the cui? The commands look like they are supposed to. I think.
- Highlight
- Email to a Friend
The CUI is not the problem.
gtrias wrote:
When I paste that in the command line I get a "nil"
Ok, that is the problem. The lisp code that those menu macros call is inside this file, and this file is not being loaded.
At the command prompt, type in OP and go to the Files tab.
Expand the section that says "Support File Search Path"
You should have a path in there something like this (the EXACT path may vary depending on a few factors)
C:\Program Files\Autodesk\AutoCAD 2013\Support"
If you are not sure, take a screenshot of this area and post it.
R.K. McSwain
CADpanacea.com | twitter | Cadalyst Tips
- Highlight
- Email to a Friend
The path is present.
- Highlight
- Email to a Friend
So to confirm,
(filefile "acad2013doc.lsp") returns nil, right?
Then the file must be missing.
Search your hard drive (you may have to enable hidden files) for this file.
If you don't have it or can't find it, do you have another machine that you can copy this file from?
R.K. McSwain
- Highlight
- Email to a Friend
See the image attached.
- Highlight
- Email to a Friend
Gentlemen, the problem is not in the CUI. Look at the command in the macro (_ai_draworder) - this is defined in "Acad2013doc.lsp" and if that file is not loading, then the macro will fail.
R.K. McSwain
- Highlight
- Email to a Friend
That did it! Thanks to everyone for their able asistance. You may all take the rest of the day off.![]()
- Highlight
- Email to a Friend
Glad to know the issue is resolved ![]()
Cheers,
Luciane
- Highlight
- Email to a Friend
Is there a way to solve it with "migration tools"?
In our office we have more than 20 machines, mostly 2010, but we started using 2013 just now
The DRAWORDER issue is one of problems we encountered now.
The system is based on the 2010 as mentioned, using the 2010acadoc.lsp as shared file on the server
As there a way to migrate the new macro (ai_draworder) ? and other macros as well?
Is it the best policy? I prefer to use one file (acaddoc) to all the machines...
maybe it's better to have one file to 2010 and another one to 2013?
- Highlight
- Email to a Friend
morro73 wrote:
Is there a way to solve it with "migration tools"? Yes. Do not use the migration tools!
The system is based on the 2010 as mentioned, using the 2010acadoc.lsp (Are you sure about that file name? There is no reason to share "acad20xxdoc.lsp" since it shouldn't be edited and it will be same on all machines. Were you talking about "acaddoc.lsp"? ) as shared file on the server
As there a way to migrate the new macro (ai_draworder) ? and other macros as well? Restore the stock OOTB "acad2013doc.lsp" from the install media.
Is it the best policy? I prefer to use one file (acaddoc) to all the machines... That is fine. Do not confuse the two files. "Acad20xxdoc.lsp" is provided by Autodesk and should not be modified. "acaddoc.lsp" is not provided, you create, modify, and maintain this file yourself. It can be located anywere (although it needs to be in the drawing directory or the support file search path to be found and used)
We do keep a separate network support directory for each version. Good idea.
R.K. McSwain
