• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Valued Contributor
    Accepted Solution
    Toolbars keep resetting & draw order doesn't seem to work.
    2046 Views, 20 Replies
    06-08-2012 05:18 AM
    We've got a few custom lisp routines and setups loaded, but whenever I restart, the loaded toolbars disappear back to the defaults. The lisp routines are loaded and the cui is there but I have to keep bringing up the toolbars.  Any ideas?
    Also the draworder on the right click menu does not seem to be working. Is there a system variable that Im missing to turn that back on?
    Please use plain text.
    *Pro
    nestly
    Re: Toolbars keep resetting & draw order doesn't seem to work.
    06-08-2012 05:34 AM in reply to: gtrias
    Toobars are part of the Workspace, so you have to save the Workspace after adding/changing toolbars for them to be retained.
    Product Support
    06-11-2012 06:01 AM in reply to: gtrias
    Nestly's suggestion should help you, let us know if that is not the case.
    Cheers,
    Luciane
    Luciane Conceição
    Product Support Specialist
    Autodesk, Inc.
    Product Support
    Matt.Desfosses
    06-11-2012 06:19 AM in reply to: gtrias
    If you go into your WSSETTTINGS and make sure the Automatically save workspaces changes is checked off.
    If that doesn't work you can always save it to a unique name by WSSAVE.
    Matt Desfosses
    Support Specialist
    Product Support
    Autodesk, Inc.
    Valued Contributor
    06-11-2012 07:23 AM in reply to: gtrias
    Thanks guys, that solved my workspace problem!  Any idea as to what might be affecting DRAWORDER?
    Product Support
    06-11-2012 07:44 AM in reply to: gtrias
    Excellent :smileyhappy:
    Do you have the Draworder command showing in the shortcut menu?
    What happens when you click on it? Is there any message?
    Have you checked the associated command in the CUI?
    Does it work if you type the command?
    Cheers,
    Luciane
    Valued Contributor
    06-11-2012 08:45 AM in reply to: luconceicao
    Strangely enough, the toolbar command says "unknown command" for each of the options.
    When I type it in via the command line, the command appears to work normally.
    Product Support
    06-11-2012 08:49 AM in reply to: gtrias
    Open the CUI window and find the shortcut menu and its associated commands. If you need assistance I suggest that you create a new post as this is a different topic from the original.
    You can send me the CUI if you wish, let me know and I'll setup an FTP folder for you.
    Cheers,
    Luciane
    *Expert Elite*
    rkmcswain
    06-11-2012 10:37 AM in reply to: gtrias
    Did you recently upgrade and if so, did you elect to use the "migration tools"?
    Regardless of that... paste this to the command line. What does it return?
    (findfile "acad2013doc.lsp")
    Valued Contributor
    06-11-2012 10:42 AM in reply to: gtrias
    Thanks for the help - This was a fresh install, but I did have a beta version installed where that problem was present too as I recall.
    When I paste that in the command line I get a "nil"
