• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    System variables sorting programs (autocad2013)
    260 Views, 7 Replies
    07-22-2012 05:06 PM
    Has anyone a easy way to compare the system variables from 2 autocads. So I can find out what setting have changed between them. E.G. my new cad 2013 can not remember the the director that I was in last. But the auto cad 2013 just beside me does remember the last directory folder is used. And my old cad2012 can ???. And I will open the first folder, that appears in the placelist. So I have to keep moving the current folder to the top each time.
    Command: '_setvar Enter variable name or [?]: ?
    Enter variable(s) to list <*>:
    Please use plain text.
    Autocad 2013 can not remember current working folder
    07-22-2012 05:09 PM in reply to: jason75
    *Expert Elite*
    rkmcswain
    *Expert Elite*
    rkmcswain
    Re: Autocad 2013 can not remember current working folder
    07-23-2012 05:47 AM in reply to: jason75
    Are you referring to the behavior affected by the REMEMBERFOLDERS system variable?
    *Expert Elite*
    Re: System variables sorting programs (autocad2013)
    07-23-2012 06:45 AM in reply to: jason75
    I think the difference you are looking for in your example is REMEMBERFOLDERS.  I don't think that is drawing resident.
    07-23-2012 04:06 PM in reply to: jason75
    rememberfolders was already set to 1. I have changed it to 0 closed cad opened set to 1 again closed and opened and still the same problem.
    *Expert Elite*
    GrantsPirate
    07-24-2012 05:48 AM in reply to: jason75
    You should set it to 0 and try it for a while.  I think help does a bad job of describing how that variable works.
    10-05-2012 12:49 AM in reply to: jason75
    Do you think there is a windows that may also affect this command
