AutoCAD 2013/2014 DWG Format
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Switching Page Layouts switches drawings
- Highlight
- Email to a Friend
- Report Inappropriate Content
When I try to switch to a different layout in a drawing AutoCAD will switch to a different drawing. Then I have to go and get back to that drawing to do anything to the layout. Is there a solution for this issue that anyone knows of because it is really starting to get annoying.
Re: Switching Page Layouts switches drawings
- Highlight
- Email to a Friend
This is getting really annoying. Even when I switch from model space to paper space it switches drawings.
- Highlight
- Email to a Friend
how do you switch to a different layout? At least the question here is have you the layout-tabs visible? (short screenshot would be fine so we see where you click or what you type)
What happens if you just set the variable "CTAB" to the name of the layout you want to get current?
And I hope you have not an application running that handles the layout switching ![]()
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
- Highlight
- Email to a Friend
I have the same problem, but it happens during a regen. any thing that causes AutoCAD to regenerate will cause it to jump to another drawing (and some times to another program I.E. fire fox or word (which ever was the last accessed befor the regen) we use sheet sets and I can change from the view tabs drawing tabs or the sheet set and it will jump to unexpected places.
- Highlight
- Email to a Friend
I saw that too, but only with Windows7. It never happened to me with WinXP or Vista.
What OS do you have?
I never had the situation that it jumped to another drawing (within the same AutoCAD session). But if you have opened AutoCAD multiple times then it just brings the current process to background (in that case AutoCAD session 1 behind AutoCAD session 2).
And that brings me to the idea: what happens if you change the sysvar TASKBAR? If it's 1 set it to 0, if it's 0 set it to 1 ... and watch how it's going on now.
- alfred -
Alfred NESWADBA
- Highlight
- Email to a Friend
I am running win 7 ultimate 64 bit sp1 with 16gb ram and 32gb page file, intel i7 870 @ 2.93GHz 2.93 GHz this has only been an issue with 2013 I ran 2012 on this machine and had no problem, I only have 1 autocad session open (others that I work with are having the same problem one is working in civil as autocad, I have the original revit architecture suite. the others just have AutoCAD) I am currently testing the "TASKBAR" suggestion
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
Setting taskbar variable does not help any.
- Highlight
- Email to a Friend
taskbar set to 0 seems to be helping
- Highlight
- Email to a Friend
I had mine set at 0 and then set it to 1. It still did the same thing either way that I had it set.
