• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Active Member
    Re: Stuck aligning boxes
    09-05-2012 07:00 AM in reply to: Patchy
    That's it.
    Please use plain text.
    *Expert Elite*
    Patchy
    09-05-2012 07:05 AM in reply to: CAD_Anatomy
    I can't open it, can you save down to 2010 version.
    Active Member
    09-05-2012 07:08 AM in reply to: Patchy
    I don't understand - when I chose to save as 2010, they broke up into 2 perpendicular lines by themselves.
    *Expert Elite*
    Patchy
    09-05-2012 07:31 AM in reply to: CAD_Anatomy
    Using 3d, you need to know which UCS plane to use, rotate the viewcube and start drawing will cause a big mess.
    Click on your 3d parts, go to properties and fix the skew.
    Active Member
    09-05-2012 09:39 AM in reply to: Patchy
    That worked perfectly! Thank you so much for your time. Looks like I still have a lot to learn.
