Sometimes SURFPATCH will not patch - Modeling Operation Error
64 bit SP 1.1 applied
Some of the 3D poly-lines refuse to be 'patched' using SURFPATCH (attached DWG)
Command resultis in this message:
Modeling Operation Error:
Operation unsuccessful.
Cannot create patch surface from the selected curves.
In the attached DWG, the thinner middle 3D poly does not become a surface using SURFPATCH, can anyone explain why, what is invalid in the 3D poly?
TIA,
Kevin.
JDMather
Is there any reason you can't do as 4 curves (actually only need 2) and Loft instead?
Thx JD ... removed the end segments and used LOFT
would still like to have a more detailed message from acad explaining what was invalid
Thx again
Kevin.
