• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Valued Contributor
    Accepted Solution
    Selecting entities - How Close?
    133 Views, 6 Replies
    11-21-2012 07:17 AM
    It seems lately, last couple of weeks I am missing entities when I try to pick on them.
    Not window, not crossing. Just trying to pick an entity. I usually select entities first before my command.
    Is there a variable that might have changed?  I played with PICKBOX & APERTURE but this doesnt change anything when I try to select something. I can have the entity in the box right next to the intersection of the crosshairs and instead of selecting the entity it starts to window. I know it wasn't like this before.
    I have a logitech m705 mouse w/ setpoint software ver 6.32.7 & driver ver 5.33.14 installed.
    Rick
    Please use plain text.
    Re: Selecting entities - How Close?
    11-21-2012 07:30 AM in reply to: Rick-K
    there is your variable, set it to 1
    and there is PICKADD, Pickauto...
    Valued Contributor
    11-21-2012 07:36 AM in reply to: Janet2009
    Thanks, it isnt pickfirst, but pickauto looks promising.  It was set to 2.
    I could pick first but had to be right on top of the entity.
    Rick
    *Expert Elite*
    11-21-2012 08:25 AM in reply to: Rick-K
    it is the variable PICKBOX that lets you define the minimum distance between cursor and entity for selection.
    Look this:
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    Valued Contributor
    11-21-2012 08:32 AM in reply to: alfred.neswadba
    Thats what I thought !!!  It always used to.
    But it didnt help.
    I think it is solved with the pickauto var.
    Pickauto kind of makes the pickbox actually work.
    I am still checking but I havent had the problem since I changed pickauto to 1 (it was 2).
    Man it was driving me crazy.
    Nice video by the way.
    Rick.
    *Expert Elite*
    11-21-2012 08:56 AM in reply to: Rick-K
    >> But it didnt help.
    I saw PICKAUTO already as one of your answers you needed. My video should be the answer to the thread-title and your first description of your issue with "how close". Anyway if you don't need it there may be some people coming in the future to read that :smileywink:
    - alfred -
    Alfred NESWADBA
    Valued Contributor
    11-21-2012 09:06 AM in reply to: alfred.neswadba
    Yes, pickbox should be the answer to the question.
    Except pickbox didn't work this time because pickauto seems to turn it off.
    It has been working fine now.
    Thank you for your help.
    Rick
