• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Script (Commands) to make filter?
    202 Views, 7 Replies
    06-14-2012 03:37 AM
    Anyone knows script (command) to make filter and then select any filter.
    I have to run this operation on several files. So, needs it script.
    Please use plain text.
    Re: Script (Commands) to make filter?
    06-14-2012 03:46 AM in reply to: vikasranga2
    what type of filter do you want to create?
    If you want to select objects by properties then you should look to LISP and function SSGET (>>>details<<<)
    If you mean any other filter like e.g. layerfilter ... let us know. A sample description what you want to filter out of what sum of ... would be helpful to support you.
    - alfred -
    Alfred NESWADBA
    06-14-2012 03:59 AM in reply to: alfred.neswadba
    I want to make filter on the basis of Layers name.
    e.g.: I have so many layers having suffix *fix, like A_fix, B_fix etc. I need the script which can filter those layers.
    After that script to select any filter too?
    06-14-2012 04:06 AM in reply to: vikasranga2
    Do you want to filter layers or to select objects on that layers (that's why I asked for a little description).
    I assume now that you want to select object (and not layers), so try
    _SELECT<ENTER>
    (ssget "X" (list (cons 8 "*fix")))<ENTER>
    <ENTER>
    ...is that what you are looking for?
    - alfred -
    Alfred NESWADBA
    06-14-2012 04:17 AM in reply to: alfred.neswadba
    Ok I am explaining whole, what I need?
    I have two types of layer groups, one having suffix *fix, and other having suffix *cat. I want to get diffrent pdfs for those, *fix & *cat layers.
    I have thought following steps:
    1. Turn off all layers,
    2. Make separate layer filter for *fix & *cat layers.
    3. Turn on *fix layer filter.
    4. Run the script to get pdf.
    Yesterday I asked you how to turn off all layers, now I am not getting the script to make filter for *fix, and *cat layers, and then turn on any filter. So, I want this one. Can I have the ans. for step 2 &3?
    Hope you understand the problem.
    06-14-2012 04:19 AM in reply to: vikasranga2
    Can you give me any file, from which I can study all about commands, scripts, lisp and macros?
    06-14-2012 04:31 AM in reply to: vikasranga2
    At least some thousands of pages in the help >>>for 2013 and search<<< or within >>>this PDF you showed me yesterday<<<
    You can't turn on a layerfilter, and if you already know layernames with wildchars you even don't need >>>layerfilters<<<
    All off ... we had that yesterday, now for on for the layernames like "*fix":
    _-LAYER<ENTER>
    _-ON<ENTER>
    *fix<ENTER>
    <ENTER>
    HTH, - alfred -
    Alfred NESWADBA
    06-14-2012 04:39 AM in reply to: alfred.neswadba
    Thank you, it worked.
