AutoCAD 2013/2014 DWG Format
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Re: Scale command message: Extremely small scale factor ignored
- Highlight
- Email to a Friend
NicholasWard wrote:Sorry, but how is this not difficult avoid? If coinciding snap points are the cause, then anywhere that two lines meet end to end will exhibit this problem. I cannot speak for others here but corners or t-junctions mark the origins of 99% of my scale commands, so this is a problem 99% of the time.
The video from Autocad 2011 is certainly a familiar scenario, but with 2013 the error message comes through instantly, regardless of whether the cursor has been moved or not.
Again, I'm not saying this shouldn't be fixed. I can easily replicate the issue 100% of the time, but I have to "try" to make it happen. If you truly cannot scale anything because it happens "instantly" I would try to be very deliberate with your mouse when picking the basepoint to see if you are inadvertenly moving the mouse when you release the button.
... or...
move the mouse a significant distance (something bigger than the APERTURE) immediately after picking the basepoint.
... or....
Create a command macro to turn off running OSnaps during the SCALE command,
I really don't think the last suggestion is necessary if you fully understand why it's happening, so I've done a more detailed demo
http://www.screencast.com/t/XfalgHOOyYy
Are you by chance using an APERTURE that's larger than standard?
- Highlight
- Email to a Friend
I have the same stupid issue. Hope they fix this soon. ![]()
- Highlight
- Email to a Friend
Me also come across this..quite very frustrating...It only start happen in version 2013.. I also hope that Autodesk can manage to come out with a hot fix on this matter after all, so many version out and i first time come across with this problem.
- Highlight
- Email to a Friend
Fred I totally agree, the scale command problem needs to be fixed. It interupts drafting work flow. And this has never been a problem until version 2013 which is dissapointing. Hopefully autodesk comes up with a hot fix soon.
- Highlight
- Email to a Friend
Have you guys reported this as a bug via the Subscription Support Request, or as a Feedback issue?
- Highlight
- Email to a Friend
Good day
I have the same problem but changed the OSNAP they spoke up - saved format in 2013 and he returned to scale.
When I saved the same file format that was climbing in 2007 he stopped to climb again.
conclusion
It is incompatibility between older formats. AUTODESK believe will solve this.
- Highlight
- Email to a Friend
My CAD Manager had me draw construction lines off to the side of the object (a .pdf image) and use them to scale the obect with.
It is an annoyance. I can work with it.
- Highlight
- Email to a Friend
I think the key point is that those who posted here with the problem (which I am also having in 2013) are having the problem because it has not been an issue with previous releases in regards to the way they are used to using the program. Apparently, I too am used to working with my OSNAPs turned on, and putting my cursor as close to the endpoint as possible when picking it. Before I noticed this post, I had discovered the workaround for me was to hover a little farther away and let the cursor jump to the endpoint before I click.
I also noticed that although I still have the issue somewhat when I choose a command through a ribbon icon, it doesn't happen as often as when I use command aliases (which are supposed to be faster and "universal"). I don't know if that has any bearing on things. Hopefully someone from the Principal's Office will notice these posts and look into it.... ![]()
- Highlight
- Email to a Friend
Hi All,
I have had this problem on both a demo of the full version, and now my own LT version. I would like to clarify a few things from the (slightly misdirected, IMHO) posts above.
a) It is core functionality that is broken. This is very clearly a bug. I cannot scale by reference in almost all cases. Occasionally I do not get the problem -- if I can figure out anything different with those files I will post. Could it be metric vs. architectural units? Anyway, scaling by reference is one of the, say, top 10 or 20 most important commands in any drafting. THIS IS A REAL PROBLEM.
b) The workarounds, while clever and helpful (thanks to all!), are huge time-wasters compared to what used to be standard functionality. I'm impressed with the depth of knowledge and ingenuity on this forum, but that offers no apology for the fact that Autodesk released software with a heavy bug in basic functionality in it. None of you has 'solved' the problem. And everybody seems to be able to reproduce it.
c) Autodesk: please fix the problem! This should be high on your priority list. It's an embarassment, frankly. It's most likely a very easy fix.
If Autodesk continues to ignore this problem, how can we escalate it? Is there a more appropriate forum for posting real bugs?
Waiting (praying?) for a patch...
George
- Highlight
- Email to a Friend
I am not sure how come for this latest version autodesk would have such a bug for this "Scale" command afterall, it wasnt a new command to them...Anyway, i also try to report this issue but then i can't find the pages to report the issue.
