• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Member
    Scale command message: Extremely small scale factor ignored
    8474 Views, 36 Replies
    04-13-2012 01:05 PM
    I've seen archived posts regarding this issue, but none were answered or relevant., although I have to admit I feel their pain.
    I have just updated to Autocad 2013. While working on existing drawings (previously created in V2012), I am having issues with the SCALE command.  Most times, but not always, when I add a line or block, with a base point on an existing line or object and try to scale it, I get an "extremely small scale factor ignored" message, although I did not get a chance to enter a scale factor.  While it appears most times, but not always, if I draw a new line in empty space on that same drawing, I am able to use the SCALE command without problems.  I also have the same issue when trying to scale an existing line or block, most times but not always.
    Here is a copy of the command line while I am trying to make it work:
    Command: l
    LINE
    Specify first point:
    Specify next point or [Undo]: 100
    Command: sc
    SCALE
    Select objects: 1 found
    Select objects:
    Specify base point:
    Specify scale factor or [Copy/Reference]:
    Extremely small scale factor ignored.
    Command:
    SCALE
    Select objects: Specify opposite corner: 1 found
    Select objects: Specify opposite corner: 1 found, 2 total
    Select objects:
    Specify base point:
    If you notice, it does not give me the chance to enter a scale factor.  As soon as I pick the base point, it skips over to the error message, yet displays the scale factor prompt with a blank factor.  I'm experiencing this issue on various files (not all but most), so I don't think it is a corrupt file.
    Any idea why I get this and if I can correct it?
    FR
    Please use plain text.
    *Expert Elite*
    Re: Scale command message: Extremely small scale factor ignored
    04-13-2012 11:28 PM in reply to: fredrivardABL
    before you can input a value for the scalefactor AutoCAD looks to the cursor and evaluates the scalefactor by the distance between scale-basepoint and current cursor-position. If you have e.g. osnap turned on (and ENDPOINT is active) it may snap to the startpoint of the line (what was also your scale-base) and that results in a scalefactor = 0.0 and that's not allowed.
    Try next time this issue occurs to switch off OSNAP for the second point.
    HTH, - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    New Member
    04-19-2012 03:43 PM in reply to: fredrivardABL
    FR, we stumbled upon this issue the other day as well and you don't need to turn off OSNAP to get around this - provided you are using F12 Dynamic Input. It seems the Dynamic Input box takes precedence over OSNAP or command line.
    HTH,
    Chris.
    Active Contributor
    NicholasWard
    04-29-2012 08:10 PM in reply to: alfred.neswadba
    alfred.neswadba wrote:
    ...If you have e.g. osnap turned on (and ENDPOINT is active) it may snap to the startpoint of the line (what was also your scale-base) and that results in a scalefactor = 0.0 and that's not allowed.
    HTH, - alfred -
    Not really an option when most people are using scale (yours truly included), as they'll often need OSNAP turned on to select the base point. The problem is that AutoCAD is now skipping the old step of waiting for user input before proceding with the command.
    This utterly pointless upgrade to the scale command has rendered it essentially useless. It still works on some objects in my drawings, but it's random whether the working objects are in converted 2012 drawings, new 2013 drawings, are new objects, old objects, lines, circles, blocks, etc.
    __________________________________________________________________________
    There are 10 types of people in the world: Those who understand binary and those who don't.
    *Expert Elite*
    04-29-2012 10:00 PM in reply to: NicholasWard
    Excuse me, I wrote "try it the next time the issue occurs", I didn't write "you don't have to use OSNAP forever".
    I just want the OP to see, that he may have a problem taht OSNAP snaps to the scale-base-point.
    Sorry that it was not to understand in that way I mentioned.
    - alfred -
    Alfred NESWADBA
    Active Contributor
    NicholasWard
    04-29-2012 10:16 PM in reply to: fredrivardABL
    Ah, sorry. I misunderstood. Still doesn't solve the problem, but yes it would show where the problem lies.
    Member
    04-30-2012 09:40 AM in reply to: NicholasWard
    Thanks for the replies, although none of the proposed solution resolve the issue.
    -The suggestion of turning on Dynamic input does not seem to have any effect to prevent/resolve this issue.  Perhaps I have a setting that is setup differently, or the scale issue you are/were experiencing is different.  I will keep experimenting with this option with various settings, although so far none has provided the expected result.
    -The option of turning of O-snap does make it work, but it is pointless since the intent is to scale objects from a specific base point.  Turning of O-snap defeats that purpose.  I might as well pick a point in empty space and get the same result.  Also, I am not convinced that this is the problem, since if you run the scale command on a line where the scale command does work, and either pick the initial base point, or enter 0, or negative digits at the "specify scale factor" prompt, Autocad returns a prompt stating "Value must be positive and non-zero".  My theory is, if the issue is caused by an automatic "snap" of the base point, I should receive the same message,  in lieu of the "Extremely small scale factor ignored message".
    Any other suggestions is appreciate, otherwise I'll keep trying to figure a way around, or preferably out of, this issue.  Nick, it does sounds like you have experienced (or are experiencing) the same problem.
    New Member
    05-01-2012 06:56 AM in reply to: fredrivardABL
    I've ran into the same problem. It does not happen every time but enough to be annoying. Instead of turning  snap off I use the snap override by typing in the abbreviation of the snap I need to scale from (end , cen, mid, ins).  another way to access snap overrides is to hold shift and right click, then select from the menu......... It does not work every time but enough to helpful....
    Active Contributor
    NicholasWard
    05-01-2012 05:54 PM in reply to: levi.connolly
    The other (annoying and not always practical) solution I've resorted to is typing in the reference point when prompted, rather than clicking it. Provided the cursor is nowhere near the ref point when it's selected, it works fine. Of course, it only works for when you know the coordinates, but at least I can scale objects until Autodesk gets their act together on this one.
    Active Member
    mbrown83709
    05-05-2012 10:48 AM in reply to: fredrivardABL
    Just upgraded to 2013 and am running into this problem as well.  To work around (provided by others in this thread) I accomplished it by turning off OSNAP and designating the base point with the ENDpoint.  After that it worked out fine.  Thanks to those who provided a work-around.:smileyvery-happy:
    Autodesk Factory Design Premium 2012
    HP Z 400 XEON Quad Core 3.06 ghz
    14 GB Ram
    Nvidia Quadro 2000
    Twin 22's widescreen
