• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2013/2014 DWG Format
    RayFeiler
    Accepted Solution
    Save All
    390 Views, 10 Replies
    09-11-2012 06:24 AM
    I know that there is a Save All command in express tools but if one does not have express tools installed or loaded how can they access this Save All fuction frome the command line? See screen shot..
    Thanks for any help you can provide. Ray
    Product Design Suite Ultimate 2014 64-Bit Update 1
    Sometimes you just need a good old reboot.
    Please use plain text.
    Active Contributor
    Re: Save All
    09-11-2012 07:42 AM in reply to: RayFeiler
    Hi can you type saveall on the command line?
    Just tried this with MEP 2013 using vanilla profile & it worked OK.
    RayFeiler
    Re: Save All
    09-11-2012 09:47 AM in reply to: lesleys
    Without express tools installed I get,
    Command: saveall
    Unknown command "SAVEALL".  Press F1 for help.
    In AutoCAD 2012, Mechanical 2012, and Electrical 2013.
    *Expert Elite*
    Patchy
    Re: Save All
    09-11-2012 10:16 AM in reply to: RayFeiler
    RayFeiler
    Re: Save All
    09-11-2012 10:42 AM in reply to: Patchy
    Yes, I know about the saveall.lsp and that's what I currently use. I was just wondering if there was a way to access the built in save all function for distribution reasons.
    *Expert Elite*
    pendean
    Re: Save All
    09-11-2012 01:58 PM in reply to: RayFeiler
    So you can't, or won't, or don't know how to install Express Tools?
    Where is your screenshot from? You're not using plain AutoCAD, right?
    Dean Saadallah LT BLOG | RSS Feed | LT Tips | PINS
    *Expert Elite*
    Re: Save All
    09-11-2012 05:35 PM in reply to: RayFeiler
    There is no built-in SAVEALL command. You need to use the LISP or the express tool.
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
    RayFeiler
    Re: Save All
    09-12-2012 05:26 AM in reply to: mathewk
    In plain AutoCAD 2012 without express tools or saveall.lsp
    qvdrawing right click on one of the views and select save all.
    RayFeiler
    Re: Save All
    09-12-2012 05:42 AM in reply to: pendean
    I can and have installed express tools. I wanted to know if there was a way to call qvdrawing right click on thumb nail and select save as via command line.
    *Expert Elite*
    pendean
    Re: Save All
    09-12-2012 06:02 AM in reply to: RayFeiler
    Final Answer, once again: NO YOU CANNOT!
    Hope that helps clear it up :smileyhappy:
    If there is a way, and so far I don't understand why you can't just install ET or the Lisp you have, the folks at the Customization Discussion area may know, you tell you the exact same thing:
    http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/bd-p/130
    So why the fear of ET installs? I.T. running your shop, instead of the folks earning the money for IT to spend?
