AutoCAD 2013/2014 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Rough Text issue
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am having difficulty with the text in my drawings. When writing dtext or dimensions on my drawings in modelspace the text appears rough/rugged in both model space and layout space. I am using True Type (Arial) as the font. I've read older posts where people have suggested checking in Properties that the text is really laying down at 0 in the Z plane which it is. Some say using True Type is the problem, but just last week I was doing what seemed to be the same operation and I had no problems at all. Any suggestions would be appreciated.....
Peter
Re: Rough Text issue
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
How about if you attach a cleaned version of the drawing with just the font? Then maybe we can take a look and see.
Windows Vista Business
Service Pack 2
Intel(R) Core(tm2) Quad 3.0 GHz
4.0 GB RAM
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
TrueType fonts only show fully smoothed (anti-aliasing) :
- In 2D Wireframe
-when the view is perpendicular XY plane of the Text
-at 0 elevation (relative to the current UCS)
-when the "target" for the View is 0 Elevation
If any of the above are not true, the anti-aliasing is disabled and TrueType Text is not "smoothed"
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Okay,
I am attaching a file of the drawing. I'll start over here and say that my desire is to be able to take 3D renderings and dimension, label, mleader, etc. them to be printed out as architectural drawings for the client. In the simplified drawing I attached, I used SOLPROF to create the drawings I have in paperspace. I acknowledge that the dimensions are not on the same plane as the desired points on the 3D model when you look at the whole picture in model space. I would like to be able to print these drawings with clean fonts.
As a side question, when I try to preview the layout to be printed I am not able to zoom into the preview beyond the paper edges so I can see the quality of the print. The window option doesn't allow me closer either. Is there a way to zoom in closer?
Peter
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You can change the font to shx.
or move the dims to paper space
or create a viewport on top of the viewport, freeze the dims layer in one, change the other to 2D visual styles with everything frozen but dimensions layer.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You have your viewport set to conceptual, thats what is effecting your text when using true type text, only displays correctly in 2D Wireframe. You could always dimension outside of the viewport so the text would not be effected.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The the text is in a view using Conceptual Visual Style, and the Target of the view is non-zero. Both of these have to be remedied before the TrueType text will display smooth.
If displaying a 3D visual style is something you need, then the previous suggestions of placing the dimensions/text in PaperSpace, or switching to an SHX font are your only real options.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I think I'm finally getting the jist of what my problem has been through all of your responses. I've learned a lot concerning this matter. Thank you all for your time.
Peter
