AutoCAD 2013/2014 DWG Format
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Release / Change serial number AutoCAD 2013
- Highlight
- Email to a Friend
- Report Inappropriate Content
Is it possible to change the serial number of an installed AutoCAD 2013?
br,
Chris
Re: Release / Change serial number AutoCAD 2013
- Highlight
- Email to a Friend
Possible? maybe.
Type in ABOUT go to Product Info, change your number in there and then Update.
- Highlight
- Email to a Friend
Thank You for Your fast response!
I tried that but it seems I can not change the serial nor is there a 'update' button:
br,
Chris
- Highlight
- Email to a Friend
as you are running a network-licensing system it's the license-server that is responsible for the serial number, you can't change it locally.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
- Highlight
- Email to a Friend
Thanks again for fast response!
Ok, I was afraid that it was not possible. I would like to change the serial since our licenses are spread over network and stand alones and I would like to have one deployment which I install and then go to the PC and update serial with proper value. I guess there is no command and/or registry key to change either (e.g. change network to stand alone)? Or would it be possible to build a stand alone deployment image which I install and then when installed, go to the PC and change stand alone to network license?
It is a shame that it is soo expensive to change stand alone to network licenses.
br,
Chris
- Highlight
- Email to a Friend
so you have different license-servers? If so you should have the option to set an environment-variable (ACADSERVER) for the license-server to be used. Try to change it then AutoCAD will use the other server (not tried yet, so it's just a guess).
- alfred -
Alfred NESWADBA
- Highlight
- Email to a Friend
No we have only one license server. But as an example, we have one set of network licenses for 4 PCs, another network license for only 1 PC and then several stand alone (+ LT-versions), Revit Structure and Revit Arcitecture (both network and stand alone).
The ability to build deployment images is really cool and I like it alot but as you can see, it is not much of help for me at the moment :-)
Thanks to the replies here I can atleast make a "Stand Alone" deployment image and then update the correct serial on these machines.
br,
Chris
- Highlight
- Email to a Friend
Update: Ok, I think I have found a way on howto drop network -> stand alone -> network. I have to test this, I'll post an update if it works.
