• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Registry key to detect Autodesk Suite products
    180 Views, 4 Replies
    02-13-2013 01:20 AM
    I installed 3 suites on my workstation :
    - Product Design Suite ultimate 2013
    - Factory Design Suite ultimate 2013
    - Building Design Suite ultimate 2013
    In the registry key, I only find "Product design Suite" installed with  "ProductEdition" Key.
    I did not find a trace of the other suites install.
    1) Do you know how to trace the other suites in the registry ?
    2) How to know in the registry if AutoCAD 2013 belongs to one of these 3 suites (cause the serial number = 000-00000000 in the registry) ?
    Please use plain text.
    DarrenP
    Re: Registry key to detect Autodesk Suite products
    02-13-2013 05:59 AM in reply to: jrchh1
    you can open up the product and get the serial number
    02-13-2013 06:56 AM in reply to: DarrenP
    My goal is to find the information recorded in the register.
    Open the product and go and check the serial number, I can do it also via _pkser.
    My real question is :
    How do I know which product belongs to what Suite in the registry key ?
    For your answer, when I launch AutoCAD 2013, I can see that Building Design Suite appears.
    In about of AutoCAD, I always see Building Design Suite and when I look at it's serial number, il belongs Factory Design Suite.
    See attached file.
    DarrenP
    02-13-2013 06:57 AM in reply to: jrchh1
    are these network licenses?
    TravisNave
    02-18-2013 07:36 AM in reply to: DarrenP
    Darren makes a good point.  If they are network seats, then it is irrelevant.  The license manager will properly handle the licensing of the product and cascade the product to the best available license.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
