• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Distinguished Contributor
    Reducing file memory size from .shp to .dxf
    152 Views, 2 Replies
    11-09-2012 09:53 AM
    Hi:
    I have just produced .dxf files from .shp files using Surpac. The problem is that the final .dxf's are that huge in terms of memory that is really dificult to open the .dxf with any version of AutoCAD
    Thanks very much
    Rafael
    Please use plain text.
    *Expert Elite*
    pendean
    Re: Reducing file memory size from .shp to .dxf
    11-09-2012 01:11 PM in reply to: RafaelMoreno
    DXF files are huge: always have been, it the nature of "text only" format that is DXF (open it in MSWord and read it, it's quite enlightening how raw that DXF data is).
    There is no way to get them smaller, it's a lousy format for your desire. You need an SHP to DWG converter instead: what are you using now to get the DXF? What exact version of AutoCAD are you using (Plain or a vertical)?
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Valued Mentor
    TerryDotson
    11-10-2012 08:05 AM in reply to: RafaelMoreno
     Consider importing your ESRI Shapefiles directly into AutoCAD with an add-on tool like MapWorks Base.
