• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Distinguished Contributor
    Light_Guy
    READ ONLY pet peeve
    127 Views, 2 Replies
    01-15-2013 07:17 AM
    Can someone PLEASE explain to me, why, when I open a drawing using the READ ONLY option from the user interface window, that I still get prompted to save the drawing when I exit??
    Paul Hamor
    "Always good ships!"
    Please use plain text.
    *Expert Elite*
    dgorsman
    Re: READ ONLY pet peeve
    01-15-2013 04:07 PM in reply to: Light_Guy
    Sometimes drawing settings are changed (e.g. custom ACADDOC.LSP file changing system variables), other times its as simple as changing the viewpoint via pan/zoom operations (yes, that is considered a save - the file is opened with the last view setting, is it not?).  AutoCAD doesn't know why the drawing is read-only - it could be a "template" DWG in a read-only folder which is intended to be saved somewhere else.  The prompt isn't completely useless.
    Adopt. Adapt. Overcome. Or be overcome.
    Valued Mentor
    01-16-2013 08:05 AM in reply to: Light_Guy
    There are times I want to copy a drawing from a previous project, make a few changes, and then save it into a current project.
    To insure that I don't accidentally change the previous project's drawing, it is safest to open that drawing READONLY, then SAVEAS to the current project.
    I can safely make changes before or after the SAVEAS.
    If I forget to saveas, when I close the drawing, it'll ask me to save or not.
    So, I actually like that feature.
    Read Ya Later -KLYPH
