• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2013/2014 DWG Format
    Active Member
    Publish to DWF or PDF
    316 Views, 2 Replies
    07-13-2012 05:53 AM
    I have never had trouble publishing to DWF's or PDF's from the sheet set manager. Now recently, when I try, It asks where I want to save it then briefly pops up the progress box. Nothing happens, though. The box dissappears and it doesn't create any files. I have tried changing the publish options as well as the publishcollate variable. This is happening to any files I try it with including ones that it worked on just last week. Have I gotten a setting changed somewhere? Does anyone have any idea what might be happening? I tried to run a repair on AutoCAD, but that didn't help. Any suggestions would be greatly appreciated!
    Nathan
    Please use plain text.
    *Expert Elite*
    Re: Publish to DWF or PDF
    07-13-2012 10:32 AM in reply to: aerotight31
    Does the background plot engine show any errors and warnings?
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    Active Member
    07-13-2012 11:11 AM in reply to: tcorey
    I (embarrassingly enough) figured it out. I had reinstalled AutoCAD 2013, and hadn't moved the plotters for DWFx or PDF to the folder on the server that we map everyone's AutoCAD to. Thank you for your response! Sent from my iPhone Nathan Horniman hornimann@bellsouth.net
